Iray Frozen Brothers for Genesis 3 Male [Commercial]
GKDantasGKDantas Posts: 200
edited November 2016 in The Commons
http://www.daz3d.com/iray-frozen-brothers-for-genesis-3-male
A real shader set to create a winter scene with a real ice Genesis 3 Male and 3 shaders to turn everything into iced objects and props.
You get 5 materials to create:
    A Crystal Clear Ice
    A Frosted Ice
    A Glacial Blue Ice
    Dispersion ON (*abbe)
    Dispersion OFF (*abbe)
Also you get 5 SHADERS PRESETS + 9 presets to change tiling:
    A Crystal Clear Ice Shader
    A Frosted Ice Shader
    A Glacial Blue Ice Shader
    9 Presets to Change Shaders Tiling ( X1, X2, X3, X4, X5, X10, X20, X50 and X100)
This set use Iray engine to create the better visual quality for your render.
All image maps are 4096 X 4096, so your renders will look amazing even in close up.
Combined with IBLs lights and a scenario the ice will look more realistic then ever before.
Dispersion refraction increase the render time.
Post edited by Chohole on
  • I already bought Iray Frozen Sisters (http://www.daz3d.com/iray-frozen-sisters-for-genesis-3-female) which also comes with the general use shaders. So, I'm wondering what, if any,  real advantage  there would be to buying the Iray Frozen Brothers as well?
  • GKDantasGKDantas Posts: 200
    The problem is that yusing only the shader you will get seams problems in figures like Genesis or even Vic, so I draw a handed painted texture for Genesis Femalçe and Male, so no seams problems happen. Unfortunatelly I couldnt create a bundle (packs submitted in separeted cant be a bundle).
    Gorgeous
