N.G.S. Anagenessis II - Revolution [Commercial]
1101113151643
  • ArtiniArtini Posts: 10,380
    edited November 2016
    These scripts are amazing. Below is an iray render of Skyler.
    NGS II script for G3 + Pores Medium Level + Lips Gloss Female
    Light rig from the Ultra Genesis product (UG Standing Rig 004 + Env 006)
    1280 x 1024 - 295K
    Post edited by Artini on
  • FistyFisty Posts: 3,416
    So make your own map for the where the micro one goes and adjust to taste - works for me!
  • Dimension-ZDimension-Z Posts: 352
    It was one way for me & for all.
    If I hadn't make it as MR, creators would be stationery. And so do I.
    I wanted to go further with texturing. But it's different if you have 4 maps to handle instead of 1 or 2 max.
    Now in this way creators can play with hires image references. And with only one diffuse map (or bump if they want too) they will be able to make magic things!
    This was only the REVOLUTION... http://orig15.deviantart.net/3158/f/2016/309/d/f/she_s_got_the_look_by_audioslave74-danebhx.jpg
    Thnx
    D-Z
    Post edited by Dimension-Z on
  • RAMWolffRAMWolff Posts: 10,363
    Ah, so the Micro map is not a merchant resourse then.  That really should be made clear on the sales page in my opinion.  I can make noise maps easily enough but not sure if I can match what you made but I'm always up for a challenge... Thanks!
    Never did get feedback on getting the eye surfaces a bit more reflective.  frown
  • FOR PALE/WHITE SKINS DECREASE SPECULAR COLOR TO YOUR TASTE.
    Thnx
    D-Z
  • RedzRedz Posts: 1,459
    xyer0 said:
    I've been testing N.G.S. on a bunch of G2F FW skins, and I'm getting (some) lacrimals that are grey to greenish. I change the Glossy Color, but I can't get rid of the grey/green in the larger part of the lacrimal. Help?
    I found this with Olympia 7, but once I switched her surfaces back to the correct UV (Olympia 7) then the lacrimal looked correct, so perhaps worth checking the correct UV for the character maps is selected.
    Yes you're right. I forgot that. Update Fix is Ready To Test by DAZ. Tomorrow you will have it!
    Thnx
    D-Z
    Used my newly made MicroDetails map in place of yours and tweaked quite a few values and colors.  Still needs more tweaking but happy with the results for the most part.
    1156 x 837 - 702K
    Great job. I wanted to tell you that. If I am not wrong, your character has a toon style so my micros wouldnt fit or with lower bump values. As I posted earlier white/pale skin need specular color decreasing.
  • NaviNavi Posts: 455
    Hello, I don't want my post to look like an unhappy customer review, as I've seen spectacular renders all over this thread by many people :) , but there must be some issues on my end, because the results I get are not exactly what I expected... Depending of the skins, I get either a blueish smurfette, or a very dark and over-saturated (greenish/yellowish tones) character. And as the shader works by stacking several very-saturated tones, I've been unable to fix them so far, except the "smurfette" effect, more or less, by changing the sss color. Without to talk about the make-ups that are totally changed by the hue alteration NGS does, and this happens with eyebrows too, sometimes.
    I don't know if there is a difference between the shader versions ? The only one I've used so far is the genesis 2 one.
    Hi Navi All Genesis versions have the same values. The product has been testing to many characters and it works with the diffuse map. A small issue with cyan gloss color has been fixed and ready these days for purchasers. As for your problem, can you please share some samples if you dont mind to see exactly what you mean? Thnx D-Z
    Hi Dimension-Z, you mean the product was updated today ? I will re-download tonight to see if there are any changes.
    For my problem, I've been testing it on a couple characters since last night, here are 2 comparison renders, to show what I was trying to explain (this one has the dark/over-saturated issue, not the "blueish" one). The make-ups, I think I can adjust that by remaking the face texture, but what I couldn't figure out, so far, is how to get them less dark (more bright, I mean), and perhaps less saturated, too. The brightness preset didn't change anything in my test renders.
    Thanks for the quick feedback ;)
    850 x 1050 - 306K
    850 x 1050 - 305K
    Post edited by Navi on
  • mark128mark128 Posts: 1,029
    Thnx
    D-Z
    By "decrease specular color" do you mean bring down all three RGB values?  Or do you mean reduce the temperature of the color?
  • CybersoxCybersox Posts: 9,355
    Thnx
    D-Z
    I saw the info on the update on your DevArt page.  Is there an eta on the geograft tutorial/script that was mentioned or is that included?
  • JerifeJerife Posts: 272
    kimh said:
    I couldn't wait so tried a quick render on a figure I am working on. I love it but wondering why it won't apply to gen3 male genitalia. I tried to choosing both at the same time, genesis 3 male and then geneis 3 male genitalia and reverse and have had no luck in getting the genetalia to render nicely like the skin. The genetalia skin remained untouched while the rest looks awesome
    It has not support for gens.
    Although I will give to all people a guide & a freebie manual system after product's releasing for easier applying on Non-Genesis Figures. (tails, genitals, creatures etc.)
    Or an addon for gens.
    Just please be patient. It was too hard for me to make all this "beast" to working.
    Thnx
    D-Z
    Bought, playing with it and waiting patienly laugh
  • I bought this product but I'm not really getting it to work. I load up michael 7 and double-click HighKey Genesis 3 but in the render it is gray like somekind of default material. I'm I using it right? I hope I can get it to work because it looks amazing
    I'm getting the same white skinned effect, but with G4 characters.  I even loaded the shaders in the default library but still get the same look.
    Thnx
    D-Z
    Just bring down the slider for all values
    Ok Navi As for the update I'm from Greece so we may have differences in our times. I saw your render. I think your problem with this isnt so big, am I wrong? Did you try decrease translucency weight?
    Did you load the correct script for Genesis 3? Did you load the convertion script first of all?
  • Does this work in 4.8 because mine keeps crashing if I add a second character.
    Another iray render. This time was FUGITIVE PRO for Genesis 2 - http://www.daz3d.com/fugitive-pro-for-genesis-2
    Sorry for the open mouth expression, but would like to show the gums and how they are improved.
    1600 x 1080 - 374K
    Not a big deal, only 1 hour between us ;) (France). And yes, in any case the shader is working here, I just would like to find a way to "police" it's effects (I mean, to have more bright and less saturated surfaces).
    Your advice gives me the feeling there is something wrong on my end, as I was fearing, because tweaking transluency was the 1st thing I tried last night, and it has absolutely no effects on the rendered result Oo : Changing the yellow color to a very pale yellow (almost white), and/or lowering the transluency value (as low as 0.005) doesn't make any difference when rendered, which is strange, for sure. To get a difference with transluency, the only thing that works for me here, is to set transluency to zero, but then the character look too pale. It's everything or nothing.
    I guess it's not normal ?
  • TJohnTJohn Posts: 11,351
    "Hitman"
    Thomas for Genesis
  • xyer0xyer0 Posts: 6,356
    Bless you, my dear Redz, that may be the issue. But where do I find the character map? (in > > > flow) I clicked on the Surfaces tab, and looked through Map Transfer and Load UV Set, but I can't find anything.
  • kyoto kidkyoto kid Posts: 41,990
    ...so I guess my question should actually be.  Which version offers the most control for creating the best looking skin possible, NGS for G3 or NGS II?  I can only afford one at this time.
    Post edited by kyoto kid on
  • fastbike1fastbike1 Posts: 4,079
    See attached. This is the only place I know to check. Select the character, go to the Surfaces Tab, Select Skin-Lips-Nails (if G3), Select Geometry ( or just scroll down after selecting Skin-Lips-Nails. Looking for UV set.
    483 x 817 - 63K
    @Fisty  "I'm very impressed by this product.  I've been having a bear of a time getting skin to look good since "upgrading" to 4.9"
    Are you sure some (all?) of your problem is that you're using pre 4.9 shaders in 4.9? The 4.8 shaders typically had a light blue SSS Reflectance tint. (as does Finley). The 4.9 shaders have a pale yellow SSS Reflectance tint.
    Here's my version of Finley with FWSA Whitley skin (4.9 shader). Same Dimension Theory HDRI as yours. 38% render. Look any better to you (image on left)? Image on right is the Finley skin (i.e. blue SSS)
    FWIW, FWSA skins tend to be a bit too tan to me, but not gray (with a 4.9 shader).
    1000 x 1414 - 2M
    1200 x 1697 - 3M
    Post edited by fastbike1 on
    Thanks for the graphic. I'm checking it out.
  • LlynaraLlynara Posts: 4,772
    I absolutely love this product. I'm revisiting previous renders and am amazed at how they are transformed by Anagenesis Revolution. Here's a G3M, P3D Outdoor Survival Dave and SAV Alphamoikana hair, with just a Dimension Theory outdoor HDRI for lighting and background. It looks like a picture! Could use some tweaking, this is slap dash out of the box, but WOW, I'm impressed!
    PS. This took only 10 minutes to render on my barely-able-to-render-Iray-box!
    941 x 881 - 1M
    Post edited by Llynara on
  • Hi, I just bought your N.G.S. Anagenessis II (very excited by the way, awesome work ;) but I am interested in it's merchant resource potential. I tried to find a read me file indicating guidelines about this but to no avail...is there any read me file included within the product folders? If not, how am I allowed to use this shader as a merchant resource? Because it's a preset, if I make my skin textures with it to include in my character packs to sell on daz marketplace, would it be working on the buyers end?
    Thanks for your time and for providing such great products
    As a Merchant Resource you can use it to aid in creating products, but anything you use should be changed to the point that it doesn't prevent or discourage the purchase of N.G.S.2
    P.S.
    For textures: The only maps you have to change for buyers end is micro.
    Hope that clarifies.
    Thnx a lot
    D-Z
    Crystal. Thank you!
