WillowRaven's latest model/product requests: Legend of the Seeker outfit
145791023
  • WillowRavenWillowRaven Posts: 3,787
    Well not for free but there are a few over at Turbosquid.
    Skipping the .max only files, start about $20.
    http://www.turbosquid.com/3d-models/pine-cone-3d-3ds/587436
    http://www.turbosquid.com/Search/Index.cfm?keyword=pinecone&x=0&y=0
    Mind you there's supposed to be free conversion available from Turbosquid for purchased files. Have no idea as to the time frame to obtain one.
    Pay-for stuff is fine, but I probably don't have time for a conversion ... your right. I'll look into it, though. Thanks. :D
    I need Optometrist tools created for a kid's book. Anybody know where I can find some, or able to create some, for me?
    Any more specific...I'm guessing you need more than an eye chart?
    Lol ... yes. A bit more than an eye chart. It's for a kid's book. The child has to go to the eye doctor and get glasses. Here are some pics the author sent me from a visit to her ophthalmologist's office:
    1600 x 1200 - 390K
    1600 x 1200 - 390K
    1600 x 1200 - 400K
  • edited December 1969
    Here's the rendered version of the Eye Scope. Anyone know what this device is actually called?
    800 x 800 - 254K
    edited November 2012
    Wow! OK ... I'm sold. I'll need to buy these in parts ... but they are mine! ... lol
    Are the textures to be included?
    Post edited by WillowRaven on
  • M F MM F M Posts: 1,388
    I believe it may be termed a "direct ophthalmoscope":
    http://www.eyes.com/ophthalmoscope.html
    HTH (^_^)n
    Post edited by M F M on
  • edited November 2012
    Yes, the textures will be included. I'm only using five textures on it and three of those are common recycled textures I use in many of my products. The other two are extracts from the images you posted above. And just so you know, creating the mesh took about 2 hours, the texturing took another 2 and 0 in research.
    Someone posted a link to a Turbo Squid model for the major optic equipment in the other forum. At the price of $80, that's cheaper then I quoted you. However, it doesn't have the table and mounting arms, which I could make if needed.
    @ M F M - Thanks for the info and link. Yep, it's a ophthalmoscope. I am sure I could have done a search to find it, but I had already put too much time in on this.
    BTW- I am sure this model is not accurate. I assume there would be a light on the back side, but I had no references to go by (without more searching).
    Post edited by cityelinks_5bd6eebab5 on
    I need two things with this current book cover project. First, I need a dilapidated old cabin. Something like this: http://kaga.wsulibs.wsu.edu/cdm4/item_viewer.php?CISOROOT=/avery&CISOPTR=810&CISOBOX=1&REC=18
    Second, I need to figure out how to create a dancing couple made totally out of blowing leaves. Any ideas?
    I'm working in DS3. I found an ideal cabin, but it's for vue: http://www.renderosity.com/mod/freestuff/details.php?item_id=64807
    624 x 800 - 426K
    800 x 600 - 352K
    1214 x 1214 - 1M
    772 x 768 - 35K
    772 x 768 - 29K
    1214 x 1214 - 284K
    1634 x 843 - 311K
    1024 x 768 - 244K
    1907 x 1027 - 533K
    1024 x 768 - 102K
    888 x 840 - 324K
    1922 x 1039 - 480K
    1922 x 1044 - 382K
    1871 x 947 - 480K
    1033 x 805 - 317K
    875 x 875 - 365K
    875 x 875 - 374K
    875 x 875 - 314K
    875 x 875 - 322K
    875 x 875 - 304K
    1024 x 768 - 192K
    1024 x 768 - 344K
    1626 x 907 - 426K
    1212 x 684 - 308K
    800 x 600 - 496K
    1251 x 767 - 179K
    1920 x 1080 - 267K
  • RarethRareth Posts: 1,462
    the dancing couple you could use Look At My Hair there is a way to export as instanced geometry and let you replace the hair with leaves..
    That doesn't work in DS3, does it?
    hmmm don't think so..
    As far as the cabin goes. Is there a way to convert a vue freebie to a usable Daz/Poser object?
    static prop? export as *.obj then import into DAZ or Poser
    But I don't have vue, so what opens it other than vue?
    edited January 2013
    http://www.cornucopia3d.com/products/vue/vue_11_pioneer/
    its free oh wait, probably can't do an export..
    Post edited by Rareth on
    ok E-on Software is entirely too picky...
    so a cabin, something like this?
    edited January 2013
    Sort of, but it needs to look abandoned an being taken over by the elements & surrounding woods. Are you building this, yourself?
    Did you see the link of the one I wish I could open? http://www.renderosity.com/mod/freestuff/details.php?item_id=64807
    yeah I downloaded it, but I don't have a program to open it, so I threw together that one in Hexagon just as an idea
  • GrazeGraze Posts: 418
    edited January 2013
    Assuming you have a 2D graphics software with layers and know how to make brushes, this is how I would do it:
    Create your scene in DS3 with M4 and V4 posed as the dancing couple.
    Hide M4 and V4, render and save background.
    Hide background, unhide M4, render and save as a PNG file.
    Hide M4, unhide V4, render and save as a PNG file.
    Load the M4 PNG file into your 2D graphics software. Use a selection tool to select M4.
    Go to the layer above the M4 layer and brush in the leaf patterns. It will all stay inside the shape of M4 due to the marquee selection of M4. You can delete the layer with M4 afterwards.
    Repeat the previous 2 steps for V4 with a different leaf pattern and / or color.
    After you remove the marquee selection, you can brush in leaves outside the shape of M4 and V4 to create the illusion of blowing leaves.
    Here are some PNG file of leaves sold by DAZ http://www.daz3d.com/autumn-leaves-resource-pack
    Post edited by Graze on
    actually this is kind of fun haven't done much in Hexagon in awhile
    I think I follow all of that. Definitely going to try it :D
  • StezzaStezza Posts: 8,749
    Don't know if this prop from PoserDirect will suffice for an ol' shack
    Vines & trees are from various packs.. leaves blowing around is from the snow tool here at Daz
    took around 30minutes to throw together & render in Carrara
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,082
    edited January 2013
    you could export M4 &V4; as an obj, open in ivy generator and grow ivy on them, import the ivy obj that results into studio and turn down the opacity for the stems.
    Dry Jack has a shack here
    Cool building. I would need to modify it and give it a porch, but it might work. Do you have a link?
    For the leaves, how controllable is that snow tool? Can I condense the pattern to fit the shapes of a dancing couple?
    Dry Jack has a shack, will look for links.
    Never heard of Ivy Generator. Definitely sounds like a cool tool. It may be just what I need ...
    And thanks for the link search ahead of time. :D
    buildings:
    www.poserdirect.com/buildings.html
    the snow tool isn't that controllable but will do for leaves blowing around the couple
    ivy generator is here Fenric did a plugin that uses it for Carrara but the standalone on an obj works quite well imported Studio and Poser.
    it just creates ivy around an obj as a seperate obj you can then save and import
    oh good the experts have shown up... :)
