Garibaldi Express: Hair and Fur Plugin Beta [Commercial]
Adding to Cart…
Ctrl-Z also works I believe.
Well I guess that's progress... Seems bizzare that the paint workspace doesn't work but all rest do...
I've been doing some work on reducing the system requirements that that will continue over the next weeks that will start to be visible in future beta versions...
This might help your Linux WINE setup or might not.
I'll be starting work on a real Linux port straight after the IRIX port...
Intergrating into the daz studio content system is on the list of things to look into when things are a bit more polished...
Yep, that's what Kerya mentioned and I have the same thing. Thought it was my computer or mouse till she mentioned it.
Nice renders, Kerya, MD, gone & gensi!
I'm working on a few (one in particular that I've changed a few times) and that I'll try to post later today if I can get it like I want and get it rendered.
It's the brows man! :lol:
The 32 bit version works quite fine, even though it's "not recommended" =) Haven't yet had the time to produce any renders worth posting!
I had the same issue as Spyro with Beta.4 with the paint going everywhere on a morphed genesis. Will go back to the same scene with .5 and see if it still happens.
Looks great... I look forward to seeing them with custom colour maps.
Did you start these hair styles from scratch?
Looks like something has gone wrong to do with the UVs...
Have you pressed the update geometry button in the setup workspace after applying a different UV set (or applying a texture)?
I realised that in beta 5 I've updated the daz viewport/rendering to surport changing UV maps but not the update button.
The paint workspace is going to to get a good looking at some point over the next few weeks. This will be fixed as well as improved speed and better quality output.
Thanks for the "good job" folks.
:cheese:
Futurebiscuit,
I did start them from scratch, (you should see my first attempts, sheesh), though I have to admit, I copied your
lighting system. Apparently, lol lighting is important.
gensi
Heehee,
I'm wanting to try all kinds of facial hair now.
Futurebiscuit,
When you work on it, is there a way to be able to access the paint that gets into the "creases" like inside the ears,
That's where a lot of my wild hairs are coming from. I can see the paint, but no matter how close I get to it, I can't
erase it. Maybe, I'm not getting a setting right?
gensi
That looks really good. Did you do the eyebrows too?
Futurebiscuit,
gensi
You have to set the brush to zero and paint those parts (yes, ears are difficult!) black.
Sometimes it's useful to do a headover and go at them from the inside of the head.
I think I may have narrowed down some of the paint problem.
If you use a textured character where the texture has more than one UV map applied, then the paint does not work. For example, I used the Dryden textures and paint did not work. Dryden uses the M4 UV map. Other M4 textures did work however. When I checked all the surfaces in the Dryden set, it turns out that Dryden uses the V4 map for the tear material zone. I changed this to M4 and paint worked just fine. I tested this idea with a number of texture sets and, in every case, if I changed even one material zone to a different map then paint would not work but did work if all the material zones used the same UV map.
On the other hand, if I change the character pose and update it in Garibaldi using the "update surfacees" button, then any existing nodes will no longer paint properly but new nodes will.
what about dynamic hair with gravity and collisions?
that's what we need...
but, it's a start.
it actually almost look the same as the other LAHM plugin.
the first one that can give me real good dynamics is sold.
how do you access the Garibaldi menu?
all i get is Create > New Garibaldi hair.
and then a new prop appear in the scene.
Then go to Edit > Edit Garibaldi
With curve based hair, dynamics/gravity aren't as difficult to get as with object based hair...but you still need a worklng physics engine to do it, so I say that's what's needed, first.
Right, I have done the erasing with the brush at zero. I've also tried to paint inside the head, that didn't seem to work.
I'll try it again to see if I was just too impatient. Thanks Kerya. :-)
Edit:
Hmmm I must be doing something wrong, I can't erase the paint from inside the head. :-S
Try turning off the following switches:
Backface Culling (Do not paint on reverse side of the surface).
Occlusion Culling (Do not paint on surface overlaped by other surface).
Hope that helps...
Hmm... I think I know whats going on here... I'll look into fixing it to support using multiple UV sets on the same figure.
To do hair dynamics 'well' it's a big project... arguably more complex than cloth simulation.
Garibaldi Express version 1 is all about concentrating about building a foundation of all the tools you need style and render realistic hair in daz studio.
If you wish to animate your character then currently the hair will 'stick' to your characters surface.
The output will render stable and flicker free.
Make sure you check out the introduction tutorial. It goes through all the basics of creating a hair render from scratch. Or use one of the provided examples as a base to work on, if you get suck on how to do things.
Turning off the backface culling switch should let you paint on the inside of the head.
Garibaldi Express version 1 is all about concentrating about building a foundation of all the tools you need to style and render realistic hair in daz studio.
I have tried a BUNCH of times to render the second image, and there are ALWAYS the same 2-4 squares (depending on the method - sprial, circular, horizontal, etc) that just will NOT render. It gets to 99% and won't finish, so I can't save as a png or anything else. Haven't a clue why this is happening or if it has ANYTHING to do with the plugin or if it's my computer. It's weird that it is the same squares every time. Tried cutting out some of the hairs in that section but it doesn't matter. I can't get these squares to render ARRRGH!!
So I did some touchup in Photoshop with the clone tool, to try to hide them
Anyway, here are my 2 attempts at the hair. Really loving it!!
Renders look great...
Can you email me the scene and I'll have a look.
Thanks
That may have been my problem. Most of my characters are all using M4 and V4 UV's except for the eyes. All of them use M5 eyes. It sucks about the UV issue. :( All my custom textures have been made for those UV's lol I never thought that the eyes would cause this problem
