Adding to Cart…
Except that's thre's really no set rule. A lot of product designed for 3DL loads just fine in Iray, frequently even without applying the shader, and my experience thus far has been that a good portion of my products that are only labled Poser actually load much better in Iray than in 3DL. It would be NICE if DAZ or the PAs went back and double checked things, but a lot of those folks aren't really around anymore and at least DAZ has their 30 day return policy.
The problem is asking some interns or something to go through 25000 products and test if they work in Iray, for a really hard to quantify and probably incredibly low increased number of sales.
I mean, yeah, it'd be great if they did that, it's just unsurprising that they don't.
Theoretically the only things that won't work with Iray are procedural materials, actual shaders (Fabricator is NOT A SHADER...it's a series of shader presets) and render scripts. The degree of how well anything will autoconvert is a matter of opinion.
It's ok, you'll get used it it. ...Just in time for me to change it again. MUAHAHAHA
lol :P
Do not fear change, embrace it! :) Change gives great hugs!
That's ilegal where i live.
All the patterns I checked (over half of them) worked fine out of the box without even changing the shader to Iray. The weave adjustments are what add the bump, displacement, and specular. Most of the weaves are already set to matte so they render pretty fine, all of the ones I checked do use displacement but it was the same texture map plugged into the bump channel so you can take it out of displacement and leave it in bump.
It does work really well in combination with my (and I assume PD's) Iray shaders. For the tweeked render I used my Fabric Basics Iray, went to the 03 Shine folder and chose what I wanted for gloss type and color, then went to 02 Color and changed the top to Tyrian purple to match the trousers.. and finally the 06 Tiling folder to make the pattern repeat 7 (Frabricator defaults to 10). You don't have to change the shader to Iray Uber before doing any of that, the Mix and Match shaders do it for you.
Note: the 07 Bumpiness folder in Fabric Basics Iray adjusts normal strength so it doesn't do anything if used on Fabricator surfaces that use bump maps, you have to adjust them manually on the surface tab.
And just for fun.. she decided to play in the 09 Dirt.
@Fisty, I'm liking your lace and jewelry.
Awesome! Thank you for your work and research on this, Fisty! :D
One thing that's kind of hidden is the texture section. Once you apply a pattern, you can apply a fabric type, so you can create something like plaid burlap or a polka-dot sweater knit.
OMG, Will. This online tool looks awesome. I can't wait to try it out.
