How can I edit with smooth curves in Hexagon?
tdrdtdrd Posts: 0
edited December 1969 in Hexagon Discussion
I am following the peter pan tutorial (sort of) for my model of a shirt.
There is a problem of many but this one concerns smooth curves whilst editing.
I attach a photograph of the video - see the smooth flowing curves as the editor manipulates the model.
Then look at the picture below - that's mine - note the straight edges.
I know I have more lines - I had to smooth it to generate more points in order to be able to shape the material.
Please can someone tell me if there is a way to get these curves smooth with less points as in the first picture - i'd be ever so grateful
Thank you.
Terry
  • ausairausair Posts: 0
    You need to apply 2 levels of smoothing to your mesh. Smoothing is in the top right corner of hexagon next to the symmetry options.
  • dot_batdot_bat Posts: 373
    not sure but couldnt you use the smoothing control cage
  • tdrdtdrd Posts: 0
    Is there a way of making 2 edges into one edge - Ie square into triangle...?
    Yes, you can weld one vertex to another. Keyboard "w" is the hotkey.
    The 1st image would have 2 levels of smoothing applied but NOT collapsed.
    Great for getting a good idea as to the finished whereabouts of the mesh however I'd recommend removing the 2nd level of smoothing [so it looks more like your 2nd picture] before welding any vertice or edges as that done with 2nd level smoothing not collapsed tends to crash Hexagon.
  • RoygeeRoygee Posts: 2,247
    If I recall correctly - the top picture is done at level 1 smoothing, with DG active - select the control curve in the DG list. It lets you work in a plasticine type mode. You don't want to go doing any welding, cutting in edges and stuff like that in that mode - just use it to shape and control poke-through. If you need to weld and/or cut in edges, take it back to level 0 smoothing and collapse DG.
  • edited December 1969
    Okay, it looked like mine does with level 2 ...
    One thing you need to be very careful of when doing subdivision modelling - meaning modelling at a smoothed level with DG active - is not to have the smoothing level too high, because when done, you will need to do additional smoothing, or the mesh will end up a lot more jagged than it looks while DG is on and you end up with an unnecessarily high poly count.
    Ideally, you should do the modelling at level 1 smoothing and finish with, at most, level 3, preferably level 2.
