Beluga
XyetztXyetzt Posts: 27,530
I found a Beluga in my content but she seems to be all white when rendered.
  • fixmypcmikefixmypcmike Posts: 19,718
    Did you apply the DS material preset?
  • XyetztXyetzt Posts: 27,530
    I thought I did
    1281 x 921 - 618K
  • FishtalesFishtales Posts: 6,228
    Looks like too much light blowing out the colour. Try changing the camera settings in Tone Mapping, raise the speed and or F-stop or lower the ISO.
    Which renderer?
    If Iray, is the camera headlamp on, in addition to the dome? (that will often overexpose a render)
  • TaozTaoz Posts: 10,324
    edited September 2016
    Well the product is called "Beluga White Whale" so it's supposed to be white. But the only mats I know of is these mat-morphs in the Poser Pose library:
    298 x 214 - 20K
    Post edited by Taoz on
    Right, they have sidecar DS files.
    it's showing that blue tinting thing.
    forgot what the fix was
    What does that mean? That it will apply DS mats when installed in DS and Poser Mats in Poser?
    I tried an Iray render using the DAZ Iray Uber Base shader after applying a morph-mat texture, doesn't look very good IMO.
    925 x 933 - 454K
    Yes, if you look at the Poser mats there's a scroll symbol in the upper-left corner of the icon -- that means there's a DS file with the same name and that Daz Studio will use the DS settings instead of the Poser settings.
  • They are pretty old models but Blackdog 1966 has done some gorgeous work with the Orcas and Dolphins. :) I'd just keep playing with the settings and maybe not do close-ups...
    http://www.daz3d.com/gallery/images/57137 http://www.daz3d.com/gallery/images/58074 ;
    Ah, OK, thanks...
    Links were broken (combined), fixed:
