Post Your Renders - #4: A New Hope
191012141550
  • A3DLoverA3DLover Posts: 198
    Thought id throw this in here:
    Bg starfield done in bryce 6.3 and modified in photoshop.
    Nebulae is a apophysis fractal render heavily smudged in photoshop.
    Planet is a default sphere with spherical fog and with a free nasa venus planet texture modified
    in the shader room of c7.
    Final render in carrara7 standard
    1600 x 1280 - 715K
  • gotwaltgotwalt Posts: 3
    edited November 2012
    Daz Genesis figure in a Miata in Carrara
    1169 x 1296 - 336K
    Post edited by gotwalt on
    Utility Truck in Carrara
    1248 x 1296 - 494K
    Antennas on a building rooftop in Carrara
    1272 x 1296 - 544K
  • evilproducerevilproducer Posts: 9,040
    @A3DLover: Nice job on the space scene.
    @gotwalt: Are you using a shadow catcher for your composited scenes? If not, it might help you integrate the added 3D elements to the background plate.
    For anybody that's interested and might not know, the shadow catcher is a shader function. To create a shadow catcher, go to the shader room, select Create Master Shader from the Edit menu. Then when the shader window comes up, select the Lighting Models pulldown menu and select the shadow catcher. You can select a couple options from there. When it's set up, apply it to whatever object you want.
    The shadow catcher will appear invisible, but it will mask any objects behind it, it doesn't catch reflections, it can be tricky to use with Global illumination and the color in the color channel seems to have an effect on the hue of the shadows. You can use it with alphas for later compositing, or you can use an image or whatever in the scene background or backdrop as well.
    I've uploaded a couple screen captures and a couple sample images.
    2000 x 1500 - 885K
    2000 x 1500 - 1009K
    718 x 478 - 85K
    650 x 457 - 114K
    274 x 277 - 35K
  • Kodiak3dKodiak3d Posts: 223
    @A3D
    Beautiful colors. Very nice pic. :-)
  • edited November 2012
    Just playing around with an old Stonemason set :)
    I needed a new desktop background, lol.
    *Added some trees and lowered the resolution for the sake of render time.
    1024 x 576 - 647K
    1280 x 720 - 1006K
    Post edited by K0daKumi_8e8836aac0 on
    Putting my bimbo through Crazy Talk....
    1280 x 720 - 888K
  • de3ande3an Posts: 915
    For some reason this made me think of the Madonna lyrics:
    "Don't just stand there, let's get to it
    Strike a pose, there's nothing to it
    Vogue, vogue, vogue, vogue"
    :lol:
    Koukotsu, how did you do the lighting in that? It's very nice.
    Post edited by Kodiak3d on
    :lol:
    Ha ha, that's Aiko for you; it's what she does, lol :coolsmile:
    Koukotsu, how did you do the lighting in that? It’s very nice.
    It's very simple actually, just a sunlight+realistic sky, 45% white ambient light, and "ambient occlusion only" ticked in the global illumination settings with an occlusion radius of 18inches. (I almost always use the "small" scene scale)
    Then, I used Photoshop to stack the image in 2 layers, blurred the top layer around 8.5%, changed it's blend mode from the layer style options to "screen" and dropped the opacity of that blurred layer to 50%. It's like adding a cheesy little bloom layer, lol.
    I did increase the brightness quite a bit for both layers to give it a more sunny look.
  • magaremotomagaremoto Posts: 1,220
    just setting up atmos and lighting for indoor/outdoor scenes
    720 x 540 - 198K
    720 x 540 - 220K
    added more bounce lights and blurred reflections, testing the shaders editor as well
    1920 x 1440 - 217K
    Nice, I particularly enjoy that dim/evening looking atmosphere.
    Wow things have really slowed down around here :blank:
    I always intend to create more purposeful, meaningful renders, but I end up rendering Aiko standing there just doing nothing in particular, lol.
    I'll probably save this character and import her into a larger scene that attempts to tell a bit of a "story" eventually, but who knows :coolsmirk:
    628 x 960 - 265K
    583 x 960 - 214K
    706 x 960 - 249K
    493 x 768 - 239K
  • bighbigh Posts: 8,147
    cute - can i pat her tum tum
  • ColdrakeColdrake Posts: 236
    Not posted here for a while! Here is a fave film character of mine...can you guess? Sculpted in 3dcoat.
    Meg Mucklebones, very cool! Great work.
    Coldrake
  • Frank__Frank__ Posts: 302
    Kodiak3D said:
    Just finished a little project I started over a year ago and got away from. I wanted to test out iPisoft's mocap system (2 Kinects) and this is the result:
    (Funny this thread should be called "A New Hope." It's oddly appropriate.)
    http://youtu.be/rpM_r2W_W2E
    This video isn't available in Germany, because of music copyrights (and stupid negotiations between Google (less) and Gema (much more)).
    So I wouldn't be so sure on the use of William's music ... :)
    I'm aware of the issue. I read what YouTube had to say about it. If I recall, it's an issue between Sony and Germany.
    Coldrake
    So that's who that is! Been a long time since I saw "Legend". Excellent work, as usual.
    Robert Picardo is the actor who played Mucklebones. He also played the alien Wak in one of my favorite movies, "Explorers".
    Stu, you should think about doing Wak. That is, if you can find any decent full body reference photos.
    350 x 388 - 46K
  • HeadwaxHeadwax Posts: 9,729
    hey I thought that was a Stu job you posted.
    Post edited by Headwax on
    :lol: Looks like something Stu would do, doesn't it? I think he should give it a go.
    Just a little "fully clothed Aiko with a sword" render I did today ;-)
    I must have used 10 different layers total, just goofing around, lol.
    1280 x 1024 - 385K
    Really nice, Kouko! It's just me, but I would have turned the blade toward the camera a bit more to show it off, but that's just my personal taste. Great pic.
    Here's a character I've been playing with for a couple of weeks. She's going to be a character in a short movie I plan to do in the near future. (Did a little postwork, which is something I don't usually do.)
    1024 x 768 - 323K
  • edited December 1969
    Nice Elven archer, she looks quite fierce! She would send my sword-wielding school girl running for the hills most likely, lol.
    Oh, and your personal tastes must be better than mine because now that you've mentioned it the angle of that Katana is driving me crazy!
    I'm redoing it :shut:
  • MattymanxMattymanx Posts: 6,793
    Hey Koukotsu! Havent seen you around in a while. Miss seeing your renders of A3/Mulberry. Speaking of which, she look very cute in those images!!!
    In case you didn't see it there is a new A3 thread here - http://www.daz3d.com/forums/discussion/8629/
    Hi there, thank you ;-)
    I kind of lost track of this forum for a while when the "renovations" were going on, judging from the way things have slowed down I'd say I'm not the only one either, lol.
    Thanks for sharing that link, I'll be sure to drop in and check it out real soon.
    I followed Kodiak's advice and adjusted the angle of Mulberry's Katana a bit, I believe it looks much better this way. I'm thinking of trying a more aggressive, less relaxed/casual expression and pose next time around, lol.
    1280 x 1024 - 578K
    I like it, Kouko! Gives a better view of the handle as well.
    You're Welcome.
    I agree that the angle is better for the sword. For a more aggressive stance, there are 4 poses in my freebie pack here - http://www.daz3d.com/forums/discussion/10844/ - that were originally made with swords so you can build off one of those if you like.
    Try doing this in DAZ STUDIO or POSER....
    Just ambient occlusion. no lights. Isometric camera.
    1280 x 720 - 94K
  • GarstorGarstor Posts: 1,411
    I hope the DS coders felt that glove slap... ;)
    The image is simple yet alluringly cool. I like it!
