Decoro
m_m_italy
Hello to all.
I modeled this form.
I have to decide its use.
I hope you do not get angry hexagon.
It 'a work of patience.
That's it.
Bye
m_m_italy
Hello to all.
That's it.
Bye
......sorry.....
test corona.....
....test anello....
Bye
Well, THAT'S a rather unexpected application!! :)
Rather pleasing. Very nice!
A brilliant image. Not what I was expecting. :coolsmile:
Thank you.
Forgive the insistence.
Here is a door candy (porta caramelle).
Render W.I.P.
Bye
Wow. That's beautiful m_m ! ;-P
%-P
Grazie Gost!
Ho problemi con internet......
Vedo male le immagini.
E parlo brutalmente male la lingua Inglese.
....e non va il copia incolla.....
Ciao
:long:
%-P
Grazie Gost!
Ciao
:long:
No worries mait! You're english is good enough. ;-)
Sorry.....ho problemi con Internet = internet problem
Beautiful work, m_m_italy.
Love the variations you created with the piece.
Very nice work!
Thank you.
Thank you very much.
I have problems with the internet and with the site.
I do not see the images.
Happens to you?
Bye
:long:
Very beautiful!!!
DAZ site has problems since May, so I am not surprised that you have some problems with it. I do see images though, no problem. If that happens to you when you are in DAZ store, try Ctrl + F5 (forced refresh), sometimes it helps.
Thanks for the comment.
Thank you for your help.
The forum does not work.
Negative.
I'm sorry because I can not see the images posted by users..........
You are not alone with this problem. Several people wrote about it in this thread. It seems that they did not find a solution yet, but try to check the thread regularly, maybe someone will find a way to fix it and posts it there.
O.K.
Thanks.
Ciao
@m_m_italy Have you checked that your file permissions have not been corrupted or missing in the control panel ?
For example .jpeg + .png + etc
Edit: Durr! I'm a twit; He won't be able to see the screen grab.
:blank:
Hi - two members already mentioned that antivirus software Kaspersky Internet Security 2012 they have on their computers might be causing it after a recent update. Do you have this antivirus also?
O'er, m_m certainly has serious issues. :gulp:
Hi,
You are absolutely right!
Use this antivirus.
I think this is the cause.
I confirm.
The problem is that I can not find solution.
He also disable copy paste from google translator.
La causa is Kasperski.
Potrebbe andare peggio......
Potrebbe piovere.....
Bye
It seems that updating from Kaspersky 2012 to Kaspersky 2013 should cure the problem - it worked for 2 forum members already. Also, one member added DAZ forum to Kaspersky white list and this helped also. You could also pause the antivirus for the time when you are browsing in the forum. Or just uninstall the evildoer alltogether and install another antivirus - that´s what I did with my antivirus when it crashed and nearly damaged my PC after an update.
O.K.
Grazie.
Bye.
