Victorian Innocence - fit problem
TaozTaoz Posts: 10,313
edited August 2016 in The Commons
When I load the Victorian Innocence corset, there's a lot of poke through. Isn't it supposed to fit by default on a zeroed V4?
I can expand it using some of the morphs but then it doesn't fit perfectly as on the promos.
Post edited by Taoz on
  • JUJUJUJU Posts: 1,133
    May be there is a morph for the shirt?
    I need to reinstall it, then I can have a look at it. I think there is a dial for the chemise..
    edited August 2016
    There is a dial in the Chemise. I made a screenshot where you can find it.
    1007 x 742 - 143K
    1007 x 742 - 143K
    Post edited by JUJU on
  • TaozTaoz Posts: 10,313
    Ah, OK, will try that. Thanks very much! smiley
    With layered clothing meshes do not use a Smoothing Modifier as it forces the outer mesh to collide with the body often through the lower mesh layers
  • kaotkblisskaotkbliss Posts: 2,918
    If you do want to use mesh smoothing, you would have the corset collide with the dress underneath and the dress collide with the figure
    Not possible when the corset and the dress are parts of the same object.
    Well they are not, they load separately.
  • sandmanmaxsandmanmax Posts: 992
    Maybe you conformed it ot V4.  Try the chemise instead.
