Victorian Innocence - fit problem
Taoz
Taoz
May be there is a morph for the shirt?
I need to reinstall it, then I can have a look at it. I think there is a dial for the chemise..
There is a dial in the Chemise. I made a screenshot where you can find it.
Ah, OK, will try that. Thanks very much!
With layered clothing meshes do not use a Smoothing Modifier as it forces the outer mesh to collide with the body often through the lower mesh layers
If you do want to use mesh smoothing, you would have the corset collide with the dress underneath and the dress collide with the figure
Not possible when the corset and the dress are parts of the same object.
Well they are not, they load separately.
Maybe you conformed it ot V4. Try the chemise instead.
