to render an image
I have no idea how to render an image I keep getting a pink visual.
Daz is more difficult then studio max
  • FSMCDesignsFSMCDesigns Posts: 12,855
    LOL, i use 3DSMax and it's not, not by a long shot, LOL
    make sure you have a camera (create > new camera) in your scene, make sure your viewpoint is looking thru that camera and make sure you have a light source in the scene.
    It's just any other app, you need to play with it till it clicks
  • Thank you
    Where wouldI find a mirror surface
  • BlueIreneBlueIrene Posts: 1,318
    I think the pink thing might be the same thing that happened to me (and a few other other people) a couple of weeks ago. As far as I remember, the solution involved upgrading graphics drivers although I could be wrong. Whatever it was, it worked like a charm. I'd try to dig up more if forum search wasn't so awful - maybe someone else with a better memory who experienced the same thing will be along soon. Good luck.
  • I think the pink thing might be the same thing that happened to me (and a few other other people) a couple of weeks ago. As far as I remember, the solution involved upgrading graphics drivers although I could be wrong. Whatever it was, it worked like a charm. I'd try to dig up more if forum search wasn't so awful - maybe someone else with a better memory who experienced the same thing will be along soon. Good luck.
    I have no idea what the pink that was about but using the camera seems the answer.
  • This is an issue with Kaspersky deleting the freeimage.dll file used by Iray. Check kaspersky's quarantine/vault area to recover the missing file (and for peace of mind check it with an on-deamnd scanner or service before mrking it as safe, though I'm certain it is clean - barring local issues).
    Spot on and nailed. Thank you
