Adding to Cart…
Thank you !
Oh, figured it would be simple, J/K. So Gianni, Michael 7 and Bodybuilder have custom morphs so they shouldn't be a problem. I just checked them and they are fine. I don't have the fitness one in my list. Does the belt reappear when you turn off smoothing? Sometimes a lot of smoothing will cause things to disapear like that.
I if you want I am willing to try and whip up a custom JeanZ morph for you. Zero the pose on the male. Zero Gianni, Michael 7 and Bodybuilder. Set the Mesh resolution on the JeanZ to base and export it out of DS as an obj at DAZ scale of 100%. I will message you with where to send it. Can't guarantee that it will be 100% accurate since I will be doing it without the reference morphs.
Cheers!
First, thanks for your support, it is truly appreciated! Yes the two versions of the JeanZ are vertex compatiable.
Sorry to hear of your struggles. I sent you an message on G2.
Cheers!
BTW, I created a free Black Leather texture (Iray) for the JeanZ that you can download here: http://www.3dpixelstudios.com/?download=black-leather-for-jeanz
Enjoy!
Thank you!
Just got my reply from Daz support and it's not good news:
"Hi Colin,
I just installed and tested in 4. and it is definitely a 4.8 issue. Updating to 4.9 should fix the issue.
Jared"
Daz, if you're going to sell content which is only compatible with 4.9 you really should identify it as such. You should also provide guidance to your PA's about what problems may occur for some of their customers and how to avoid them as best as possible.
Well, I guess it's time for a refund. First one I've ever had to request.
Edit: This is going to add a whole new level of caution when I'm thinking about buying an item. How will I know if it will work in 4.8 or not? I really hope the PA's get some guidance on this issue so we customers can make a more informed decision when making purchases.
I don't expect a company to provide backward compatibility forever, but to cut off the immediately previous release so quickly is annoying.
That's it? Nothing else? Well that sucks, now wishing I hadn't moved to 4.9 for development, (I resisted for a long time, guess not long enough). I did find a build of 4.8 on my laptop and going to give it a try to see what happens.
Don't feel bad, you had no idea that there is some sort of incompatibility between 4.9 and 4.8. You've shown excellent concern for the issues a few (very few) of your customers are having. I'd like to support you and not return the product, but if I can't use it, well....
I've made a new thread about this incompatibility issue in general since I feel buyers need to be aware of it but please don't feel I'm picking on you. It could have happened to any PA.
I have the same issue with this product on my G3F character. I also use DS4.8 pro
I have the same issue with this product in DS4.8.
Nope, it is not a unique issue. I have exactly the same problem with this product on my g3f
Cosmo, you may wish to post your experiences in this thread http://www.daz3d.com/forums/discussion/105026/warning-new-purchases-may-not-work-with-daz-studio-4-8#latest so that others can see it's not a unique problem.
I feel this issue is too important to be buried in a thread about one specific product.
I found a beta copy of 4.8 and see the same issue. Trying to see if I can fix it. If not I may try to rebuild it in 4.8.
Those having issues in 4.8 and looking to keep using the JeanZ I did find a temporary workaround.
You can update the hierarchies/weight maps using the Transfer Tool. The weight maps in the groin area will be off, but it will be useable until I can get the installer updated.
This looks like a MUST HAVE item! Awesome! I can't wait to get it!
I've not been able to get G3 clothing to fit well onto G2 figures, so I'd recommed the Genesis 1 item and using autofit.
Nope, I don't have it.
was about to say this thought I'd check first see if anyone else posted but yeah these work great on g2 with product you mentioned tried on most of my g2f only one found have to fix backside but all the styles work great from full length to daisy dukes and tried few poses with no problems
where can I find this transfer tool?
Thanks very much for checking into this! My request for a refund hasn't gone through yet, so I was able to try your workaround and it works well. I do appreciate the way you're supporting your product & users.
Cosmo, look under the Edit menu, Object --> Transfer Utility.
Ahh, it is a little hidden. This image should help. If you have any issues just let me know.
It should also be in the Edit>Figure menu
Thanks Richard! I tend to forget about that way.
Sign me up for TreadZ for G3. I've been using the G1 version all the way up till now through G2 and G3, but it requires a lotta corrective zBrushing. Just the Iray mats alone would be worth the purchase.
Now DS4.8 crashes when trying to load the JeanZ into the scene, wanted to try the thing with the transfer utility but when loading the JeanZ into the scene to try it it crashes. UPDATE: forgot to select g3f. If just loading the pants without selecting the figure before DS4.8 crashes.
Seems that I will not buy any more new clothes from now on for g3F and G3M because it is not sure that they will work in DS4.8.
Hey that works, great thing, thanks for the information
now the jeanz work in DS4.8
