Mystery Fangs in my Genesis 2 Female
I made a character with G2F and josie 6, but have discovered she has fangs!!  i have looked all over and can't see a control that brought them in--they are a complete mystery to me.  Does anyone know about them, and how to make them invisible?  I'm puzzled and feeling helpless.
  • takezo_3001takezo_3001 Posts: 2,044
    It could be from an unnoticed morph that has been transferred over if you've used any morph transfer program or method, otherwise, I really have nothing to offer you in the way of a solution.
  • As far as i know, it is a stock G2F figure with Jpsoe 6 dieled in. Well, i suppose i should just have a teen vampire with braces!
  • If you click on one of the fangs with the Surface Selection tool what gets selected in the Surfaces pane?
  • "Teeth" is selected, in common with all of the teeth, but nothing in particular beyond that.  Node selection tool chooses the upper jaw.  But i see no controls that allow fangs to be morphed.  I will try to reproduce the same conditions.
  • I was wanting to be sure they were part of the base figure - they are obviously well back in the mouth. You can double-check which morphs are applied by looking at the Currently User group in the Parameters pane.
  • nicsttnicstt Posts: 11,715
    if the worse comes to the worst, make them a seperate material zone and then turn the opacity to zero.
  • thanks so much!
