Mystery Fangs in my Genesis 2 Female
Rowan_Jedi_Knight
I made a character with G2F and josie 6, but have discovered she has fangs!! i have looked all over and can't see a control that brought them in--they are a complete mystery to me. Does anyone know about them, and how to make them invisible? I'm puzzled and feeling helpless.
It could be from an unnoticed morph that has been transferred over if you've used any morph transfer program or method, otherwise, I really have nothing to offer you in the way of a solution.
As far as i know, it is a stock G2F figure with Jpsoe 6 dieled in. Well, i suppose i should just have a teen vampire with braces!
If you click on one of the fangs with the Surface Selection tool what gets selected in the Surfaces pane?
"Teeth" is selected, in common with all of the teeth, but nothing in particular beyond that. Node selection tool chooses the upper jaw. But i see no controls that allow fangs to be morphed. I will try to reproduce the same conditions.
I was wanting to be sure they were part of the base figure - they are obviously well back in the mouth. You can double-check which morphs are applied by looking at the Currently User group in the Parameters pane.
if the worse comes to the worst, make them a seperate material zone and then turn the opacity to zero.
thanks so much!
