Some DNA purchases not appearing in Daz
2»
  • cherpenbeckcherpenbeck Posts: 1,418
    Ah, thanks! That looks interesting!
  • TaozTaoz Posts: 10,341
    Taozen said:
    Also, if you sort by Order # in the Account Manager all the RDNA products will end up at the bottom of the list with "null" as order #, as they have no DAZ order #. This way you can separate them from the DAZ products. Note that RDNA products purchased at DAZ after they have been transfered from RDNA will not be included, as they do have an order #.
    BTW, you can also select "Order #" under Search, and then input "null" in the field, then you'll get the RDNA items only. You can export the list in CSV format via File > Export Data (this will export the files currently listed).
  • Rogue MaleRogue Male Posts: 20
    Is it not appearng in DIM, failing to download, or failing to install once downloaded? Have you tried downloading from your Product Library page and then manually placing the zip in the DIM Downloads folder?
    That was going to be my second option. I will give it a try.
    I placed it in a zip file and downloaded it to my content folder. Once inside, I opened it and I get pictures, but no completed files or models of the items installed.
    And to answer the question of DIM, it will download, but once there. All I get is a message of "Install Failed". I beleive that the content my not be completed. I was mistaken about the vender. The one I meant say was Esha. I think that is the creator and RDNA is the assistant. I guess.
    960 x 540 - 119K
    960 x 540 - 114K
    1920 x 1080 - 246K
    I also discovered that there is not product page for it. Here's the image of what I got when looking for more information on it...
    1920 x 1080 - 114K
    some rdna stuff missing from my prodlib.
    are we supposed to send list to daz support?
    almost bought the sugar outfit texture set again >.<
  • xyer0xyer0 Posts: 6,502
    Taozen said:
    xyero said:
    On second thought, Taozen, I'd prefer that you finish Product Manager for Renderosity, if you please.
    It has first priority currently. It's been delayed further though because I've decided to make some improvements to the interface which will simplify things a lot. When that is done I'll probably make a commercial pre-release for those who can't wait for the final version. I'd prefer to wait but people are getting impatient...
    I signed up for your mailing list, and I want Product Manager as soon as it's available.
    Thanks, you'll be notified then as soon as it's available. yes
  • Richard HaseltineRichard Haseltine Posts: 111,173
    Using a shrunken screenshot makes it hard to make out the details but judging by the last one, showing the folder view, the Poser-format content tree is in a sub-folder of a Daz Stusio Content Directory. Where exactly are the files, and what are your content directories (the folders you have DIM set to install to - click the Details check-box in the Ready to Download or Ready to Install tab - and the folders that are listed in the Content Directory Manager in DS - Edit>Preferences>Content Library tab>Content Directory Manager)?
  • Today is 08/02/2017, & I just noticed a RDNA item missing from my daz3d.com account. I guess it's too late to do anything about missing items at this point.
  • Maybe I have it saved on disc. That will work. blush
    Maybe, but if you don't open a Sales Support ticket you won't know. Do make sure it's a real RDNA item you bought, though (if possible include the invoice number) - I had a ticket open for an A3 item by LLF which I could see sitting in my libraries without its being in my account - only it turned out to be a different A3 item with the same name from Renderoisty that I had blush
