Genesis Meets Poser - Introducing DSON Importer for Poser
Adding to Cart…
Paris, I missed your earlier posts, but did you ever point your Poser library at your DS Content folder that you installed the "Genesis Starter Essentials TRX" to, as well as the Runtime you installed "Genesis Starter Essentials for Poser" to?
Excellent, that means I could also use Syyd Raven's Vanilla Sky textures on V5, and Natasza, Miss Wendy and Mamita too of course!
Genesis has become exciting now!
Just the way things always should have been. You do have to ask though....
WHAT TOOK SO LONG!?
CHEERS!
PS (We need multi quote on here!)
um.... i dont think so, as im not sure what you mean by point to? lol, sorry
BTW there is a new version of DSON
if you have any problems loading morph please update
the last file are
DSON_Importer_for_Poser_1.0.0.9_Win64.exe ( for my system )
if you have different build installed make sure to update as the first installation created problems with the morphs
it may help
Where have you installed your clothing? It sounds to me as though you need to install the clothing in the same library as you installed Genesis.
A rule of thumb would seem to be, if it's for Genesis, install it where Genesis is.
CHEERS!
EDIT: Your problem could also mean that you forgot to download and install the DSON Genesis core content.
Thanks for the heads up, mine is the latest one.
CHEERS!
DSON Importer for Poser - Genesis Starter Essentials - Poser Companion –PC
DSON Importer for Poser - Genesis Starter Essentials - DSON Core - PC
make sure you have the last versions
you may have the first DSON Importer for Poser - DSON Importer for Poser - Win that was updated already see my last entry
this is the same as the 32bit version I downloaded friday & still stuck on libraries freeze
Have you got the latest version of Poser 9, as in the SR3!? DSON only works with the SR3 versions of both Poser 9 and Poser Pro 2012.
Checking Flash is up to date can't hurt either.
CHEERS!
im not sure what you mean really, i installed the starter essential trx file to my daz studio directories that wer loaded in default, Content Path: C:/Users/London/Documents/DAZ 3D/Studio/My Library
DAZ Studio 4.x Files Path: C:\Program Files\DAZ 3D\DAZStudio4
DAZ Studio 4.x Files Path (x64): C:\Program Files\DAZ 3D\DAZStudio4
and the poser files to...C:\Users\Public\Documents\Poser Pro 2012 Content\Downloads
running windows 7 btw
I removed everything manually before installation as it always messing with my system
check the build number of all downloads so you are sure they match ..
here once again
DSON_Importer_for_Poser_1.0.0.9_Win32.exe or 64 for
bellow go to My Library
14812_GenesisStarterEssentialsPoserCF_1.6_dpc.exe
14812_GenesisStarterEssentials_1.6_trx.exe
DSON Importer Plugin into Poser relative path
there is not content for Poser native Runtime all content go to My Library that will be your new Runtime after you ad it in Poser
Did you download and install this file?:
If not, that's the problem.
CHEERS!
CHEERS!
latest version of poser 9 sr3, latest version of dson , flash uptodate & still library freeze
the only workround involes having poserpro 2012 at the moment, DAZ say they know what caused it , but am still waiting on a fix
Oh, right,
I guess they must be working on something. I switched to PP2012 ages ago.
CHEERS!
I hear about that and they working on that ..
the only workround involes having poserpro 2012 at the moment, DAZ say they know what caused it , but am still waiting on a fixWell we have an idea on a fix. Since we can't replicate it here we are relying on a couple of off site testers to see if what we think fixed it, actually fixed it. Then we have to test the importer to make sure we didn't break anything else with the fix. Here in Utah is is 9:22am on a Monday Morning :)
Sorry my wand is in Olivander's for its annual maintenance. :)
I appreciate the effort & the time difference, But you've got me sitting on a fence wondering is its worth picking up a load of genesis items while a sale is on, which I've been told ends today !!
When you open up Poser, there should be an icon like this in the library:
http://screencast.com/t/vLv3lFagjSfe
Click on that icon (a folder with a + and a person on it), and add the DS directory that you installed Genesis Starter Essentials TRX.
According to the User Guide wiki, Poser needs that directory, and the directory that you installed Genesis Starter Essentials Poser to, added to the Poser library. Poser's got to know where to find stuff, too! :D
thee libraries in Poser2012 are very drag and slow also after the installation including the posing in view port , the rotation not so this have nothing to do with open gl or flash as I have all updates on my i7 and DS run like hot butter
it did not freeze anything but showing not normal behavior after .. I can work with that for now but would be great if someone check on it
I had the problem of the library freeze with Poser Pro and it's due to the preferences : go to the preferences, tab "library", one must check "External" and not "Embedded".
That way the library is floating, I don't like it but at leat it no longer freezes ...
Trying to help so please forgive my relative ignorance of DAZ Studio setup.
Do you have the rest of your content installed to .....Studio4? My default path is Studio without the 4 at the end. The only things in the Studio4 folder are some Reality files. Just something to check.
that is a good trick .. I will check out if this work for me with poserpro2012
studio is correct for the data and content no studio4
thats true didnt even think about that, im reinstalling now
wouldn't that be the right place tho as its the program files folder and not the my library folder? not sure just asking, its what the installer had as the default. i really dont know.
In Win7 my default path is C:/Users/John/My Documents/DAZ3D/Studio/My Library
Obviously the John is the folder path on my PC only.
The Program Files might be saved from when you installed the main program.
Think positively! Now you can Alt-Tab back and forth between your library and Poser, and you have even more screen space for the preview window!!! :D
If you really miss having your library always visible, there's an option in the External Library that says "Always on Top" that you can check, too.
http://screencast.com/t/x0aCffaCi3r
Got a question, though. I haven't been having the slowdown problems, but then I primarily build in Lit Wireframe display mode. Does fiddling with your display settings help the slowdowns at all?
Cath is right. When DAZ Studio 4 hit the market last year DAZ was making a folder in My Documents> DAZ 3D called Studio4 and then made on called just Studio. I think they are not using the Studio4 folder any longer. A few merchants are still catching up with this but DAZ3D is installing only to Studio, not Studio4 so forget about that. All I did was grab all the useful content from the Studio4 folder and drag and dropped it into the Studio folder and deleted the Studio4 folder to keep from getting myself confused. So if anyone is installing these Poser files to the Studio4 folder.... I don't think it's going to fly right. Don't know for sure but just forget that older setup. Just use this path: ...\Documents\Daz 3D\Studio\My Library
