Daz Studio Pro BETA - version 4.9.3.166! Release Candidate 5 (*UPDATED*)
1356729
  • barbultbarbult Posts: 26,540
    How do you hide vendor categorization for assets in DS 4.9.3.37
    The product FWSA Edgar HD for Michael 7 has the figure incorrectly categorized in Figures>People>Male>Real World>FWSA Edgar HD for Michael 7. It should be in the level above, Real World. So I right clicked and selected Categorize. I removed the check mark on the FWSA Edgar HD for Michael 7 category and placed a check mark in Real World. However, the change I made won't stick. The categorization stays at Figures>People>Male>Real World>FWSA Edgar HD for Michael 7. I have Show Hidden Vendor Categorizations unchecked in Preferences.
    I thought the bug in 4.9.3.25 was supposed to have been fixed in 4.9.3.37, so I guess I don't understand how to get rid of vendor assigned categories.
  • Roboman28Roboman28 Posts: 210
    As you are fixing "failure to upgrade CMS database issues" could you tackle fault as reported by
    http://www.daz3d.com/forums/discussion/89536/4-9-2-updating-cms-takes-too-long-to-load#latest
    Specifically
    2016-26-26 17:26:02.198 WARNING: cloud\dzcloudtasknotifier.cpp(178): Unexpected exception in upgradeDb: ERROR:  duplicate key value violates unique constraint "compatibility_base_content_content_id_compatibility_base_id_key"
    DETAIL:  Key (content_id, compatibility_base_id)=(121364, 149) already exists.
    I had reported this as a bug report but gave up as the assigned admin was clueless on programming or scripts.
  • Hiro ProtagonistHiro Protagonist Posts: 699
    edited July 2016
    I don't have Edgar, but I looked for a similar incorrect categorization in another product. In this case an "info" icon was categorized under Figures/People... down to a vendor's custom category. It was also in a more suitable category and I tried to delete the incorrect one, but as you say, the change was not stored. I even went in to Edit Metadata and edited the category there (and checked purge unused categories)—no change. I'm sure this didn't use to be a problem in previous versions.
    I don't like these custom categories that some vendors make specific to their product (i.e. it includes the product name). That in my opinion is not what Categories are for, and I don't see what use they are to the user, frankly. It's fine if they create a category because there isn't a suitable one for the asset, but it should be something generic that could be used for other assets should they come along.
    I did fix it, by the way, but by the brute force method of deleting the custom category. That worked!
    Post edited by Hiro Protagonist on
    Thanks for confirming that it doesn't work the way I assumed it should work. I've submitted a help request.
  • RAMWolffRAMWolff Posts: 10,373
    Question for Rob or Spooky.  On the Transfer Utility is there a way to add an option for Auto Follow to be checked off or on?  I find when creating content that Expressions, regardless of the figure used, leaves all the Auto Follow and Limits off so if they are meant to be hidden followers they are exposed and no auto follow so stuff like masks, beards and other stuff like that won't follow along as expected!
    Thanks!
  • Richard HaseltineRichard Haseltine Posts: 109,378
    Are you talking about morphs or bones? The Genesis 3 figures use bones for most expressions.
    Morphs.  This is not a DAZ figure.
    Also, I need to understand the Memorize function.  When I use it all the rotations go gray but the values are still present.  If I save a pose out from a memorized pose will it save correctly or will be messed up?
    memorise sets the values as those to be restored to using a restore command, it doesn't change the values needed for a rotation (unlike the bake rotations command). Poses work normally still.
    Ah, OK.  thanks for giving my mind some relief!  lol
    Well it sort of works.  If I use symmetry to mirror the pose after I've made some changes to it .... looks very very bad, that's all I can say.  cheeky
    I've been going back and forth with customer service over this, and things are getting worse. They now tell me to delete the .dsx file from the Daz Connect cloud data folder and reimport metadata. This cannot be how this is supposed to work - manually delete files from Daz Connect cloud data????? I tried to do what they said, and the product lost its icon, and it didn't fix the problem. I'm frustrated.
  • LindseyLindsey Posts: 2,011
    edited July 2016
    I stumbled across a method to remove the vendor assigned category/categories and change to a preferred category/categories:
    1. Select icon(s), right click and select Categorize.
    2. Click the "Remove from All Categories" button to remove all existing categories
    3. Assign your preferred category/categories and click Accept.
    EDIT: Nevermind - the test I performed was for items assigned to the Lost and Found category, which isn't an issue removing and changing categories
    EDIT 2: I had reported this issue on July 6th in this thread.  I'll file a problem report too and see what response I get.
    Post edited by Lindsey on
    RAMwolff, the symmetry function will multiply any scaling done to the figure, be sure to uncheck Scaling and Translate boxes.
  • almahiedraalmahiedra Posts: 1,367
    So... what I did wrong... I think, was to export the metadata I had worked on and reimport it. I was hoping to find a way to provide the metadata to others.
    What is the proper way to provide user created/modified metadata for others to consume, which will not lead to issues with vendor data or cause database confusion?
    I'm not sure it's wise, or even desirable, to provide modified metadata for other people's products to others. Is there really a "market" for this? I would think it would be better to encourage people to modify it themselves. I guess people might be grateful for metadata you have created for 3rd party products from stores that don't provide it (i.e. almost anywhere that isn't DAZ) but I wonder whether anyone would want to go to that trouble.
    As for for your own created products, such as freebies that you want to share, that shouldn't be a problem as there is no prior vendor data to affect. I've never tried it but including the product metadata that you have created, including the product image, is simply a matter of including the relevant files from runtime/support.
    What I'm unsure about is what I would instruct the recipient to do in order to get that support metadata into their databases in the simplest and most undisruptive way. I recently shared by own "Product" with someone but I didn't include the "support" files (i.e. the metadata) because I didn't know what was the best thing to tell them to do to import it.
    Rain on a guy's parade, why don't you?
    I constructed working metadata for MOS Invasion and two of its add on products. I thought others mind find it useful. It hurts no one if I make that data available in the proper way for it to be consumed. I don't understand your resistance to the idea from any practical stand point.
    In rendo there are metadata packs for buy. I don't know if it sell well. Sell or share metadata sound as good idea for me, but not in packs because you can not own some of the products associated to some metadata in the pack. If the metadata is shared free, twice best. And I very able to make my own metadata, but de magnitude of this amount of work is frightening.
    If the metadata is for products without metadata usefulness is more than obvious, and this is the type of metadata that I would want see being shared. If the metadata is for products with metadata it depends on what change are made.
    Yes, well aware.  This Memorize function and then using the Symmetry tool do not play well together from my own findings...
    I agree—that was a poor response. I note we haven't had any input from DAZ staff on this thread for quite a while. Releasing public betas is essentially asking customers to put work into testing the software and I think a thread devoted to a beta deserves regular responses from the developers—I don't want to be a PIA but I am disappointed.
  • AlienRendersAlienRenders Posts: 798
    Can we expect sperical cameras that are available in iRay 2016.1 anytime soon?
  • MasterstrokeMasterstroke Posts: 2,357
    Trying to get a public build  failed for me. This smart content, download manager whatever is to much for me. I just don't get it. Can we get back to those good old times, where you just click "download to..." and then click on "install to..."? I have enough of all this cryptic stuff being put on my !!!Windows System only C-drive!!! without asking me. This is my computer and I want back controll over it.
  • frank0314frank0314 Posts: 14,766
    The only thing that has to stay on your C: is the manifest folder and files. You can put everything else on a separate drive and just point DIM to it.
    Is this Last Public Build still availeble?  I cannot See ist in my DM. I Fan see  Public beta add ons like the GoZ Plug in but no DS beta.
    The manifest files can also be moved but it requires adding the path manually to an .ini file for DIM (this is for Windows, don't know how or if it can be done with Macs).
    edited July 2016
    Thank you for your answer, but "???". I seriousley don't have any idea, what you are talking about. All this is way over my head. I feel like a newbie. I think, I give up on this. No luck with DS4.9. I'll go back to 4.8.
    Again thank you for trying to help. :)
    Post edited by Masterstroke on
  • Does anyone know if when you load up a pre-made Genesis 1 character in DAZ from 4.8 to this new version that the foot size/legnth morphs "reset" with scaling leading to -10%? It was a bug in a previous beta.
  • wizard1200wizard1200 Posts: 240
    Will this version support the 1070 and 1080 graphic cards?
  • DAZ_SpookyDAZ_Spooky Posts: 3,100
    That requires a change from NVIDIA which we don't have yet.
    Thank you very much for the fast reply. Does this mean that a software update from NVIDIA and from DAZ3D is required to use these cards?
    It might just be a driver change, it might require more. At this point in time it is too early to know what may or may not be needed.
  • asymptoteasymptote Posts: 29
    What's the trick to getting the beta to show in this dim thing ? tried every and all filter, show hidden etc , nada , not a thing.
    why no direct link like 99.9% of the rest of the internet ?
    Have you "purchased" a beta before? Below is copied form the beta FAQ:
    If this is your first time downloading Daz Studio Pro BETA, simply follow this link, click the "ADD TO CART" button on the page and then follow the checkout process.
  • nicsttnicstt Posts: 11,715
    edited July 2016
    Any news on IRAY support for 10 series cards?
    I don't have one, just kinda curious as the new Titan is due soon, and my fingers are itching; Nvidia have crippled the new Titan as they felt it was taking sales away from the pro card, so want to be sure IRAY is in no way part of that; if so, it's colossal waste of cash.
    Incidentally, not only is it a software 'fix' but the silicon used for the consumer card doesn't have the components (or greatly reduced numbers of them) on the pro card. Looks like it's more related to deep learning functions, but want to be sure.
    Post edited by nicstt on
