MDL question, controlling multiple choices
2»
  • CzexanaCzexana Posts: 167
    mjc1016 said:
    Open a text editor, copy the code Esemwy posted and save it as <something>.mdl into a folder mapped as an mdl directory.  Then drag and drop into Shader Mixer...
    Sorry to bump this thread, but where do you map a folder as an MDL driectory? I'm trying to create a custom MDL brick, but can't figure out this step ...
  • Richard HaseltineRichard Haseltine Posts: 111,831
    In the Shader Mixer pane's own menu bar, not the main DS menu bar, Edit>MDL Directory Manager...
    Thanks Richard, I'll try that later. Knew it would be something simple ...blush
    edited June 2016
    ... but clearly still too difficult for me.
    I've attached the MDL folders dialogue - I created a couple and put a copy of the .mdl in both just in case it had to be in the 'My Library' path too. But when I try to drag the file from a Windows file browser window it just shows a crossed out circle as the mouse cursor and doesn't let me. Any ideas?
    476 x 464 - 41K
    Post edited by Czexana on
    Is Windows perhaps protecting that folder as it would the C: drive version? Try using a location not in "Program Files", which should not be used for content.
  • EsemwyEsemwy Posts: 578
    Is Windows perhaps adding a hidden .TXT extension to your file?
    Okay, not sure what was causing the problem - when I got home it worked fine on another PC. May have been a syntax error in the MDL that I corrected ...
    Is there a way to get selectors on the brick inputs (so you can set a constant input without feeding something in to the input) as the standard bricks have?
    208 x 322 - 19K
