New Release: Dystopian Weapons Cache [Commercial]
124»
  • KageRyuKageRyu Posts: 0
    rg5a said:
    Font too thick?
    yes. I'm not sure which font Greycat uses, but I do not have one that matches exactly installed, so I used one of the closer I could find.
    For my attemp I used a custom light set I have made for promos and such. I just set the render to textureless, and rendered over neutral grey. I saved out of Poser Pro as a png which took care of transparancy nicely - just slipped a layer underneath filled with white.
    I added the green arrows to try to show the parenting chain, but looking back I think they may just be more confusing than helpful, and adding unescessary clutter.
  • GreycatGreycat Posts: 332
    I used SF Cartoonist Hand a free font from Blambot comic fonts
    http://www.blambot.com/
    I got it there along time ago and I don’t see it listed, but there are a lot of similar fonts.
    Thanks for the info Greycat. I could probably track it down now that I have the name. There are a lot of Font Archives out there (I even have a lot on CD uninstalled, so it might be there somewhere too). I used to collect fonts, but I'm on my third PC gearing up to upgrade again, been through over a dozen HDs... so not everything got reinstalled the last few times.
  • Moebius87Moebius87 Posts: 0
    KageRyu said:
    Got some poses up for m4, mentioned in commercial area. Here's some of what I have been using the weapons for.
    Did you ever get the link to the free seamless tile hires camo patterns I sent you?
    I was originally playing with a plug-in filter, then I decided to try painting a few which I then ran through a couple of filters. In the end they look like urban camouflage patterns with a hexagonal base grid. I have about sixteen variants at the moment, but I will attempt a few more for vehicles also.
    Cheers! — Möe
    On another note...
    It would be awesome to see some "zombie-fighting" renders (in keeping with the upcoming Halloween season), using the retractable twin bayonet attachment for our Baradum-AR.
    :cheese:
    Cheers! — Möe
    600 x 450 - 49K
  • rg5arg5a Posts: 74
    Also good for marshmallows... :cheese:
    Moe;
    Just a little FYI, it’s not really possible to pose Baradum with the drum magazine in place. With the hand on the hand grip there is no way you can bend the arm that it doesn’t pass thru the drum magazine.
    Perhaps it would be possible to lengthen the top of the magazine so drum hangs below the gun as shown?
    600 x 600 - 23K
    600 x 600 - 28K
  • myotherworldmyotherworld Posts: 572
    I think you just need to rotate the hand a little
    Greycat said:
    Moe;
    Not a problem at all, Greycat.
    We could easily extend it a little bit, but dropping it as low as you've shown might make this very ungainly. I've looked at a number of "drum" magazines and the reason that they all work is because they are in a standard (not bullpup) configuration. I should make that adjustment for you. :)
    Cheers! — Möe
    I agree that a drum magazine in a bullpup is probably not a good idea. Perhaps it in your next set you could make a standard assault rifle that would use the same magazines as Baradum.
    Well, usually you have several magazine types for each gun, but it's rare that they can be used for another one.
    The drum magazine is more for a support version (LMG) BTW, so you'd rather use it prone, with a bipod, trying to force the hostiles to keep their heads down while your squad assaults/flanks them.
    Yes... already in the works... for now it's called the "Assault Rifle - Standard Edition" or AR-SE for short. We love our catchy acronyms in Dystopia. :cheese:
    Cheers! — Möe
    Kool!
    We are on SALE!!!
    Just letting you know that the entire Team-Dystopia product theme category is on sale, including the Dystopian Weapons Cache for 30% off until the middle of the month. :cheese:
    I've also modified the drum magazine as requested and tyger_purr is working on adjusting the textures. He should be checking in here shortly with an update.
    Cheers! — Möe
  • Tyger PurrTyger Purr Posts: 0
    I have the mag setup and the cache repackaged. It will be an additional prop.
    Now i just need to upload it to DAZ and let them do their part.
    Cheers! — Möe
    Oh, i see how you are.... Two can play at that game :-P......
    Möe should have the new assault rifle ready very soon >:-D
    A little render in honor Of your sale!
    600 x 600 - 83K
    I have uploaded the updated files to DAZ.
    I have just received word that the update is now live. There is an extended drum mag added for the baradum and a couple of tweaks on the extended mag and existing drum mag insertion location.
  • HaruchaiHaruchai Posts: 1,884
    Thanks for the update and for letting us know, appreciated :)
