The I Wanted Mousse But Got A Moose Instead Complaint Thread.
18586889091100
  • ps1borgps1borg Posts: 12,776
    DanaTA said:
    ps1borg said:
    DanaTA said:
    MistyMist said:
    watching witcher playthrough here.  running around a swamp, silver sword out, killing kikimoors
    run into bandits, switch to steel sword,
    Bandits aren't worth the fine dinnerware?   laugh
    Dana
    silver swords are more of an undead thing, you wouldn't expect the. to work on the living :)
    I don't know...being pierced with a sharp sword would hurt no matter what it's made of.  You mean if a silver sword pierced your heart or lung, it wouldn't kill you because it's silver?
    Dana
    Yeah. but bandits would want to steal the silver swords but they wouldn't steal the steel swords.  By the seashore.
    undead usually aren't armoured but bandits might be so you use the steel sword on them, assuming they don't steal it first :)
    ps1borg said:
    DanaTA said:
    Dana
    Dana
    +10 armour piercing :)
    I am trying to write an urban fantasy novel but it is hard to write it with DS.  I want to play in DS instead of write.
    edit: there is a naked girl on my screen as I am having difficulty getting the CMS to work right.
    make it a graphic novel?
    with naked girls smiley
    edited June 2016
    DanaTA said:
    MistyMist said:
    ps1borg said:
    MistyMist said:
    what is the sound of attenuation?
    Diminishing retunes?
    Victor Borge would have asked "What is the sound of aelevenuation?"
    Is that like the number 11 on Marshall Amp dials?
    sound of attenuation not louder than the sound of a generator test run?
    Attenuation is the act of reducing sound.  In other words, turning down the volume!!!  Attenuation in itself makes no sound at all, it has an effect on the sound coming from something.  The term is usually used in electronics, namely amplifiers and mixers.  Sound technicians use the word attenuator where everyday people would say volume control.
    Dana
    Wouldn't that technically be the inverse of a volume control?
    Depends on where your "normal" is.  If the signal being controlled is normally permitted through at functional levels, then you might design your equipment to "attenuate" the signal to achieve a desired effect or to match the levels of other less powerful inputs.  I've seen "Attenuation" in powers of 10 or in decibels implemented as discrete switches.  However, there's nothing to prevent it being a continuous control instead of discrete.
    One could argue that volume/amplification/attenuation are matters of semantics but I'm sure there are experts out there who know the accepted lingo better than I.
    However if you look at the basic concept of a signal it has three primary controllable aspects; Amplitude, Frequency, and Phase.  Each aspect can be modified separately.  The terms "Attenuation" and "Amplification" would seem to be applicable to the Amplitude but not the Frequency or Phase.  Whereas the Phase is "shifted" and the Frequency is "Increased/Decreased???"
    My understanding is attenuation always applies to amplitude, for example when daylight is attenuated by dust it gets darker, when clouds clear it gets lighter, irrespective of any phase or frequency shift   :) So a poesis of amplitude would be dawn, or dusk.
    Post edited by ps1borg on
    saying nuh-uh to watching fallout4 playthroughs!!!!!!
    Dana
    the day analog public   broadcast signal died
    Dana
    digital tv is still free here, not that I can see it where I am we haz to use a sattelite dish the past 20 years or so :)
  • fixmypcmikefixmypcmike Posts: 19,692
    ps1borg said:
    Dana
    Still free, but no longer analog here.
  • DanaTADanaTA Posts: 13,341
    kyoto kid said:
    MistyMist said:
    ...looks like everyone else is gettng the rain we usually do.  Hoping Annie and Ed are OK.
    She was on Facebook early this morning.  I haven'g been on, but got a notice she shared something that I posted.  This was around 8:45 this am...probably my time, so maybe an hour earlier in Texas.  Strangely they are one hour behind us in time zone somehow.
    Dana
    Tjohn said:
    DanaTA said:
    Dana
    Dana
    I wonder if that hurt when he did that?  laugh
    Dana
  • TJohnTJohn Posts: 11,339
  • LeatherGryphonLeatherGryphon Posts: 12,110
    edited June 2016
    Complaint:  I had ordered a new 2TB hard drive to replace a 1TB drive in one of my external enclosures.  Everything was hunky-dory until I plugged the new drive into my 7-port USB hub.  It should have worked.  But didn't.  Then I discovered that none of the 6 (yes, six) drives plugged into that USB hub were now working.  After crawling under the desk, checking cables, and power I started methodical diagnosis.  I determined that if each of the six drives were one-by-one plugged into one of the front panel USB ports the drives each worked OK.  (whew !!) So it had to be either the USB hub or the up-connection cable. or the backside USB port on my computer, which meant more crawling under the desk.  I was almost about to brave the dust and spiders again but decided to test the hub itself a little more carefully.  I eventually determined that I could get three drives and the up-connection to work and then reasoned that inside the USB hub there must be two chips each driving four ports (7-downports and 1 up-port) and sure enough the four ports that are functional are all grouped together at one end of the hub.  So I guess I blew a chip.  I suppose that's OK, the hub is about 8 years old.  However, I'd have expected Belkin products to be a little hardier based on the price I had to pay for it.  Then I had to explain why, at one point, none of the drives were working.  I suspect that if a drive is plugged into one of the bad ports, it boogers up and jams the data bus in the hub.  But if those ports are empty then the other four work?.  Good enough explanation.  But I'm happy because I can continue my work because I don't need all 6 external drives active at one time much anymore, it just saves playing musical cables,  but I really should start looking for another 7-port hub.
    ps1borg said:
    Dana
    We're surrounded by office and apartment towers that bend the free-to-air channels out of shape, especially when you try to record and time shift a program, the satellite works fine so long as it doesn't rain much XD
    DanaTA said:
    Dana
    Is always tomorrow here, relative to you
    159 x 30 - 7K
    Dana
    If you think about it attenuation might sound like a skateboard moving on a concrete slope, doppler and all ?
    Graphic like WARNING GRAPHIC IMAGES OF ... ?
    edited June 2016
    'Nother complaint:  I've decided to take my Vista machine and convert it to a Win7 machine.  But I don't want to lose my Vista configuration.  So I completely removed my Vista hard drive temporarily and replaced it with a brand new 1TB empty hard drive and used my remaining unactivated Windows7 OEM installation disk to install Win7-SP1.  Worked great, installed quickly without problems except it doesn't yet recognize my video board and has defaulted to a basic video setup but I can get 1440x900 resolution so it's workable for now.  HOWEVER, after checking that it had access to the internet I told it to start performing Windows updates and it just sits there saying it's checking for updates.  the performance meter shows one processor 95-100% busy and the other processor about 5-10% busy.  I've left the machine on hoping that it will eventually do some downloading but now it just sits there being quietly busy without any visible results.  Is this normal?
    PS: after virgin installation of Win7 it had InternetExplorer8 installed.  I couldn't get WindowsUpdate to work so I manually went to the Microsoft site and downloaded InternetExplorer11 which installed along with a bunch of needed updates and is working fine but I still can't seem to get a reasonable behavior out of WindowsUpdate..  I checked on the Internet and there are reports of similar behavior and some things to try but nothing definitive and the one patch that was suggested refused to run on my machine (says: "not for my machine").  Some people said they just waited it out.  So that's what I'm going to do.
    ps1borg said:
    Dana
    tee hee
    so if the train leaves its station and the other train leaves its station
    and the trains meet,
    then how fast were they moving?
    edited June 2016
    ps1borg said:
    ps1borg said:
    Dana
    This little town is 60 miles from Buffalo and down in a valley so the only people who get good broadcast TV are those with VERY tall antennas or those who live on the hills.  When I was a kid (in the '50s & early '60s) we got one channel OK, a second with snow, and a third in a continual blizzard.  Then TV cable came to town, then eventually satellite TV. Nowdays everybody has marvelous HD big screen entertainment.  Analog broadcast is gone but digital broadcast from Buffalo is available but still not practical for this town.
    But do you remember (or still experience) rapid ghosting and flashing when an airplane bounces the signal as it crosses the path?
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    Just fast enough!  laugh
    Dana
    Do you have USB 3.0?  New stuff is usually built on the USB 3.0 spec, these days.  I think I still have USB 2.0 in my box.  3 is supposed to be much faster, something you'd want especially with a hard drive.
    Dana
    ps1borg said:
    ps1borg said:
    Dana
    Oh, yeah.  I remember that!  I remember seeing the ghost of a different channel overlaid on the channel I was watching, too.  I think that happened more with UHF in the early days, but not sure...it's been a long time.
    Dana
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    Was that a scene in The Matrix ?
    edited June 2016
    DanaTA said:
    ps1borg said:
    ps1borg said:
    Dana
    Dana
    That explains a lot :) The old analogue signals would bounce around in atmosphere, and off water, as well so on a cloudy night you could hear radio from China, perhaps you still can
    360 x 207 - 34K
    Tjohn said:
    poor guy
  • kyoto kidkyoto kid Posts: 41,900
    Tjohn said:
    DanaTA said:
    Dana
    Dana
    ...me after a 12 oz cup of Turkish Coffee. (and yes, I did drink one)
    ps1borg said:
    Tjohn said:
    got rid of that awful roommate and now I got a new roommate but I do not know her yet.   Hopefully the new one will be better.
    Having difficulty signing into Word so I can go back to writing my book.  I am either thinking of calling it "new face" or "Zombie lifes matter"
    Edit Guess Zombie lives matter already became a meme.  Oh well.
    A little worried that you started with "got rid of that awful roommate" and ended up with zombies.
    Oh guess I rather deal with a zombie apocalypse than that girl.  At least the zombies won't lie that they want to play with your head or eat your brains.
    is easier when all you need iz a few silver bullets and a clove or two of garlic :)
    MistyMist said:
    ps1borg said:
    Dana
    tee hee
    ..if they were Amtrak Trains in Ohio, at best 10 - 12 mph.
    edited June 2016
    ...workstation is off for the next couple days, 100° temps not healthy to rendering.
    Not pleased with the city on a couple accounts tonight
    For one, they misprinted the festival schedule schedule.  Apparently the fireworks were last Friday, even though the festival just started today. Went all the way down there for nothing.  I want my bus fare back.
    More seriously though, a school where a friend of mine teaches was found to have dangerous concentrations of lead in it's water system.  Most likely has been like that for decades. Nice they finally told the staff that the other day.
    Why is it that are people who are supposed to be so smart act so stupid?
    Post edited by kyoto kid on
  • PetercatPetercat Posts: 2,321
    kyoto kid said:
    Petercat said:
    ps1borg said:
    This idea really took off hey
    And now we have Amazon Drones. Gonna get awfully crowdwd up there, and ugly. When you can't take a photo of the scenery without drones in the sky, it will be time to leave. Somehow. To somewhere.
    ...you could always get one of these:
    But then the scenery would be littered with dead drones. And they aren't biodegradable.
