Question about Xtech Dreadlock Ponytail
zombietaggerung
in The Commons
Less about the hair and more about the mask. It it possible to hide the little respirator dealies on the sides, without it leaving a gaping hole in the mesh? I have an idea for something, and yes $10 is cheap, but limited funds make me wary before commiting to it. So if anybody has this and would be willing to let me know if those things can be hidden, I'd be eternally grateful.
I just took a look and if you remove/hide the respirators you are left with holes, neat ones but holes.
Ah rats. Ok. Thank you very much.
On the other hand, kitbashing is fun! Try hiding the respirators and then create a primitive cylinder to make a disk to fill the hole. Use a texture shader to taste.
I recently did something similar to fix some buttons that were distorting on an outfit.
Yes, that did occur to me, but I ultimately figured something else out. I still want to buy that hair, but I can wait a little while longer.
