Question about Xtech Dreadlock Ponytail
Less about the hair and more about the mask. It it possible to hide the little respirator dealies on the sides, without it leaving a gaping hole in the mesh? I have an idea for something, and yes $10 is cheap, but limited funds make me wary before commiting to it. So if anybody has this and would be willing to let me know if those things can be hidden, I'd be eternally grateful.
link to item
  • scorpioscorpio Posts: 8,533
    I just took a look and if you remove/hide the respirators you are left with holes, neat ones but holes.
  • zombietaggerungzombietaggerung Posts: 3,941
    Ah rats. Ok. Thank you very much.
  • lexbairdlexbaird Posts: 168
    On the other hand, kitbashing is fun! Try hiding the respirators and then create a primitive cylinder to make a disk to fill the hole. Use a texture shader to taste.
    I recently did something similar to fix some buttons that were distorting on an outfit.
    Yes, that did occur to me, but I ultimately figured something else out. I still want to buy that hair, but I can wait a little while longer.
