Carrara Academy for Light of Heaven
1246714
  • 3DAGE3DAGE Posts: 3,311
    HI All :)
    LOH :)
    for writing with particles, you'd make a path, and have the particle emitter follow that path.
    Use meta-ball particles, since they join together, like a liquid would.
    You have an option in the particle emitter which allows you to "emit now" and that can be key-framed (on and off)
    so, you can have the particles stop being emitted at the end of the letter, and start again at the start of the next letter, shape, or word.
    you can set the emitter to be invisible, or, have the particles emit from another object, such as the nib of a pen.
    For the IK chain link tool,..
    This is for creating IK chains in your own figures,.. figures you've bought, like V4 M4 etc, don't need this, and they can be posed easily in carrara. .. you can select both hands and / or, feet at the same time,.. and move / rotate them.
    You can also create IK target helpers (target helper objects) (like a "Null" object in Daz Studio).
    IK target helpers allow you to move the helper objects, (instead of the figure bones) and the figure will follow those targets.
    If you open a new scene,. and then go to File / Import ..then browse to wherever you have V4 or M4 located
    (EG: Poser 8 / Runtime / geometries
    then load the Victoria 4 CR2 file,.. Carrara will offer you some import options, such as "Create IK target helpers"
    which creates target helper objects for the hands and feet.
    For the question about V4 and Hair caps...
    When you apply the hair to the Cap object, .. then that will be the object which shows up in the hair room.
    the hair cap is only parented to the figure,. so the figure won't show up in the hair room, only the object the hair is applied to.
    You don't need to use the hair caps,.. you can grow hair directly onto the figures head, but.. hair caps have a textured surface which can help sell the illusion of hair.
    AtticAnne :)
    The Carrara native content installer only comes with the Full version of Carrara,... you also get a bunch of "bonus" Daz3D content, like V4 / M4, and carrara shaders.
    The carrara native content gives you a bunch of preset shaders, sky's, clouds, tree's, example scenes, plus a bunch of simple models, from Aircraft to Ziggurat's,. Everyday objects, food, animals vehicles, etc.. and Buildings
    everything you'd need to get started.
    Hope it helps :)
  • KimberSueKimberSue Posts: 353
  • VIArtsVIArts Posts: 1,526
    Particles I found the option to switch from keyframes to motion paths, but I have yet to figure out how to actually create the path.
    IK Target: IK TARGET is what I meant. :D But do you really need to import the .obj to load the targets? Clicking on the chain thing on the left hand toolbar and then clicking on something, like a leg, seems to work. However it doesn't work when you click the foot or hand. You'd have to click a shin or toe instead.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,299
    you can use lightbulbs with crossscreen and a point at camera modifier as the particle object
    I never used a path before but just did one so not THAT hard!
    500 x 281 - 936K
    edited October 2012
    used sparks as basis, I always modify existing particle presets
    1880 x 744 - 285K
    247 x 641 - 41K
    763 x 643 - 91K
    711 x 735 - 82K
    704 x 685 - 91K
    Dear golly, my path drawing was absolutely horrendous!And it didn't draw the picture, it made balls all along the whatever-I-drew and diudn';t stay on the XZ axis.
    you have to draw from top, front, side etc view, not with the camera or directors camera.
    depends which particls emitter you choose what it does, where it falls or spurts up etc.
    thats why I start with a preset that does some of what I want.
    I drew on the ground looking down as I wanted lightbulb forming letters and not much movement from the point of origin
    chose sparkles and modified it to not spread much, emit more and longer.
    for blood dripping writing you might try simple water on a front view with a red texture for example.
    it is all trial and error.
    I had never done it before and found at least 5 ways not to do it before I succeeded.
    Thanks, Wendy. I was using metaballs like Andy suggested, but it was only making spheres every couple inches. I couldn't even tell I'd drawn a path at all. Maybe I need to up the influence or particle count?
    I managed to draw a ROUGH path, but...why aren't the particles getting stuck on it?cc the emitter just blasts them into the air all the way through.
    HI LOH :)
    here's a quick example of particle writing,. it's a simple "Hello" written with the motion path tools, but should allow you to see the settings use in the particle emitter, and to rip it apart (experiment with) to try your ideas,.
    try adjusting the motion path, to a different word or shape, or changing the colour of the particles over time.
    https://dl.dropbox.com/u/7907045/Particle_Writing.car
    If you look at the settings for the particles, you'll see that there are a lot of particles per second, (to make them more fluid and connected) and that they last for the entire length of the animation,..
    the drawback to that is ... as the animation progresses, there are more particles to calculate, and that slows down the process.
    rendering should be pretty quick.
    Oh, It it. So my Velocity hasto be at 0 or the particles will just keep shooting up instead of staying on the line. Right? And you make the cured lines by adding points and then moing them?
    e
    Gimme an A, Mr. Andy! Gimme an A because I'm smart!
    Today, I'e been playing with terrains. I learned two things about them. The first is, they're so big that I can hardly tell if I'e made what I want or where I put it in the scene.
    sAnd second, trying to paint my own map in Photoshop brings nasty results.
    HI LOH :)
    yes,.. you get an "A" + :)
    Whenever you make a particle system it's important to think about the way the particles should move, or not,.. in the scene...
    So, particle velocity and the dispersion angle, are just as important as how gravity and forces effect the particles during their lifetime.
    The Motion path can be adjusted using the path tools to move points, and the little (bezier handles) allow you to change the curve shape,.. there's also a "convert point" tool, to change from a smooth Bezier curve, to a sharp angled corner.
    With terrain's,.. or anything else,.. it's important to start by using the right scene size,.
    If you start with a Large scale scene,. then the default measurement will be in MILES,. and the default terrain will be 10000.ft
    You can also us replicators, and terrains together to "Tile" a single terrain, to make a Massive terrain. (see pic)
    Carrara has a really great set of "terrain shaders", which allow you to create rocky and grassy areas and are dependent on parameters from the terrain, such as "slope angle", height, etc..
    Just as with any shader,... you can change the simple "colour" in the shader,... to a texture map,. or a more complex mixer
    It's probably best not to use a single texture map to texture an entire landscape.
    The terrain tools and Carrara's mixers, can be used to create a semi-random (texture map - mix) based on height , slope etc
    also,.. if you select any object in the carrara scene,.. and hit "0" .. the camera will "Zoom to fit" that object into the view.
    Use the "Directors camera" for moving around in the scene,. you can also save camera positions, which you can then use with the other scene camera's.
    1256 x 796 - 191K
    Also,... :)
    for terrain building , it's important to remember that you don't need to make a single terrain which is massive and contains all the features your imagination can throw at it,..
    You can make several different terrains,.. for example,. a desert plane area, using (one terrain),... with distant mountains using (another terrain)
    you can also use other objects, like Infinite planes,. or Oceans (in the pro version) to fill gaps, or create lakes / seas.
    NOTE : ..If you want to work with Human figure's in a terrain,.. it;'s best to use the Medium scale scene, then your camera movement and scale will be easier to work with.
    the same principle applies to an animation with a smaller figure, like a bird or insect. or a snail....
    800 x 600 - 34K
    Andy, Is that snail available in poser format ? or even OBJ as long as it has material zones.
    Ooh, can I ride it?
    Ah, neer mind it's too slow. :P
    blah, I pick em off my plants and thow them against the fence and smash them, snail bait poisonous to cats, coffee grounds kills them, the caffine makes their metabolism go to fast!!
    Where I lived before we used to teach our snails to fly, they weren't always very good at it, could be because we had a 12 foot high wall one side of the garden, and they didn't get the knack of getting enough elevation before they reached it.
    I TOTALLY misread "metabolism". I thought you said "masturbation". SMH. I guess I do need to pay a visit to Jeff's doctor.
    I don't think Andy will let you babysit his pet snail now. lol
    :grrr:
    things NOT to do using particles!! and M5's geograft does not work in Carrara anyway :red:
    My internet was out all darn night. So I just played around in Carrara making a landscape, which I had to redo THREE times because of the power going out.
    Here's what I got. Rendered with high settings on purpose because I was bored.
    640 x 480 - 21K
    I don't kno if I'm happy with it. In renders like this, it's important to show distance. I don't know what you see, but to this isually impaired guy, it looks like you can take two steps and sit on the mountain.
  • bighbigh Posts: 8,147
    if your model is small in foreground - it will look big and far off
    looks like a volcanic island to me.
    mangroves all around the edge.
    That's what Ithought too, Wendy.. I'm working on getting amore poeaked mountain. I don't like the noise either, so...
    Well, I got better mountains and (I think) bedtter noise. I'm trying to put the sun above and behind them.
    Is there an option to "Move to Floor"? Because my terrains seem to be so high when I start and AT 0-0-0, they go under my ocean, which is at XYZ: 0-0-0.
