Rendering issues
holydragon
I am having issues with rendering in daz studio 4.5 and bryce 7.Studio simply crashes upon initialization of any render.It was previously working fine.
Bryce worked great too for about 2-6 renders and then.... well better to show you than describe it.
Please post your computer specs...amount of RAM, CPU, video card and operating system (version and whether 32 or 64 bit)...
Windows 7 ult x64
What driver version for the video card and any info in the Studio log file...Help > Troubleshooting > View Log (I think)?
Those specs look good...other than the memory limit in Bryce, you shouldn't be hitting those kinds of problems.
The log file should also be in Users\\AppData\Daz 3d\Studio4 folder (forgot to add that above...my daughter didn't log out and I posted under her name...)
here are my specs you asked for.... how do i upload the log.I tried different ways but was unable.the log file is way too long to copy and paste.
Delete/rename the file (I prefer renaming) and then try a render so all you have in it is the single session.
Then copy and paste and paste it, into a 'Post Reply" not a 'Fast Reply'.
*** Scene Cleared ***
DEBUG: End DAZ Studio to Hexagon Bridge log...
--------------- DAZ Studio 4.5.0.114 exited ------------------
+++++++++++++++ DAZ Studio 4.5.0.114 starting +++++++++++++++++
Platform bits: 32
Qt Version: 4.8.1
Running on Windows XP, Build 2600, Service Pack 3
CPU String: AuthenticAMD
Stepping ID = 2
Model = 1
Family = 15
Extended family = 6
CLFLUSH cache line size = 64
APIC Physical ID = 3
The following features are supported:
SSE3 New Instructions
MONITOR/MWAIT
x87 FPU On Chip
Virtual-8086 Mode Enhancement
Debugging Extensions
Page Size Extensions
Time Stamp Counter
RDMSR and WRMSR Support
Physical Address Extensions
Machine Check Exception
CMPXCHG8B Instruction
APIC On Chip
SYSENTER and SYSEXIT
Memory Type Range Registers
PTE Global Bit
Machine Check Architecture
Conditional Move/Compare Instruction
Page Attribute Table
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Hyper-threading Technology
CPU Brand String: AMD FX(tm)-4100 Quad-Core Processor
Cache Line Size = 64
L2 Associativity = 8
Cache Size = 2048
Total Physical Memory: 1023 Mb (1073741823)
Available Physical Memory: 1023 Mb (1073741823)
Total Virtual Memory: 4095 Mb (4294836224)
Available Virtual Memory: 3909 Mb (4099805184)
Current Memory Usage: 32%
Thu Sep 20 23:56:56 2012
Temp folder: C:/Users/Link/AppData/Roaming/DAZ 3D/Studio4/temp
Total temp disk size: 764899 Mb, Available: 254154 Mb
Locale: en_US
No translator found.
Reading style definition C:/Program Files (x86)/DAZ 3D/DAZStudio4/resources/style/Highway.style
Creating managers
Reading help index
Reading help file C:/Program Files (x86)/DAZ 3D/DAZStudio4/docs/DAZ Studio/DAZStudioHelp.dsx
Reading help file C:/Program Files (x86)/DAZ 3D/DAZStudio4/docs/inlinehelp.dsx
Scanning import folders
Scanning content folders
Using GLEW 1.7.0
Supported OpenGL extensions:
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_instanced
GL_ARB_ES2_compatibility
GL_ARB_explicit_attrib_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64 : NOT INITIALIZED
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_provoking_vertex
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_image_load_store
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_subroutine
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_swizzle
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_S3_s3tc
GL_EXT_texture_env_add
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_Cg_shader
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXTX_framebuffer_mixed_formats : NOT INITIALIZED
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_provoking_vertex
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_store
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_format_BGRA8888 : NOT INITIALIZED
GL_EXT_texture_integer
GL_EXT_texture_lod : NOT INITIALIZED
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_shared_exponent
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_storage : NOT INITIALIZED
GL_EXT_texture_swizzle
GL_EXT_texture_type_2_10_10_10_REV : NOT INITIALIZED
GL_EXT_timer_query
GL_EXT_transform_feedback2 : NOT INITIALIZED
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_import_sync_object : NOT INITIALIZED
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KTX_buffer_region
GL_NV_alpha_test : NOT INITIALIZED
GL_NV_blend_minmax : NOT INITIALIZED
GL_NV_blend_square
GL_NV_complex_primitives : NOT INITIALIZED
GL_NV_conditional_render
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_explicit_multisample
GL_NV_fbo_color_attachments : NOT INITIALIZED
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragdepth : NOT INITIALIZED
GL_NV_fragment_program
GL_NV_fragment_program_option
GL_NV_fragment_program2
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_gpu_program4
GL_NV_gpu_program4_1 : NOT INITIALIZED
GL_NV_gpu_program5
GL_NV_gpu_program_fp64
GL_NV_gpu_shader5
GL_NV_half_float : NOT INITIALIZED
GL_NV_light_max_exponent
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_shader_atomic_counters : NOT INITIALIZED
GL_NV_shader_buffer_load
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_expand_normal
GL_NV_texture_lod_clamp : NOT INITIALIZED
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NVX_conditional_render : NOT INITIALIZED
GL_NVX_gpu_memory_info
GL_OES_depth24 : NOT INITIALIZED
GL_OES_depth32 : NOT INITIALIZED
GL_OES_depth_texture : NOT INITIALIZED
GL_OES_element_index_uint : NOT INITIALIZED
GL_OES_fbo_render_mipmap : NOT INITIALIZED
GL_OES_get_program_binary : NOT INITIALIZED
GL_OES_mapbuffer : NOT INITIALIZED
GL_OES_packed_depth_stencil : NOT INITIALIZED
GL_OES_rgb8_rgba8 : NOT INITIALIZED
GL_OES_standard_derivatives : NOT INITIALIZED
GL_OES_texture_3D : NOT INITIALIZED
GL_OES_texture_float : NOT INITIALIZED
GL_OES_texture_float_linear : NOT INITIALIZED
GL_OES_texture_half_float : NOT INITIALIZED
GL_OES_texture_half_float_linear : NOT INITIALIZED
GL_OES_texture_npot : NOT INITIALIZED
GL_OES_vertex_array_object : NOT INITIALIZED
GL_OES_vertex_half_float : NOT INITIALIZED
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_EXT_swap_control : NOT INITIALIZED
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_ARB_render_texture
WGL_ATI_pixel_format_float
WGL_EXT_create_context_es2_profile
WGL_EXT_extensions_string
WGL_EXT_framebuffer_sRGB
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control_tear
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
WGL_NV_multisample_coverage
WGL_NV_render_depth_texture
WGL_NV_render_texture_rectangle
: NOT INITIALIZED
OpenGL features for current hardware:
OpenGL provider: NVIDIA Corporation
OpenGL renderer: GeForce GTX 460/PCIe/SSE2
OpenGL version: 4.2.0
Maximum number of lights: 8
Number of auxiliary buffers: 4
Number of texture units: 4
Depth buffer bit resolution: 24
Maximum OpenGL texture size: 16384 x 16384
Current OpenGL Texture Quality Setting: High Quality
RGBA color bitplane resolutions: 8 8 8 0
GLSL version: 4.20 NVIDIA via Cg compiler
Shadow mapping supported
VBO supported
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzassetiofilters.dll
dzautofit.dll
dzautoriggerbasic.dll
dzautoshaderbakeractions.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcontentdbeditor.dll
dzcontentlibrarypane.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdelightrenderer.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfaceshoploader.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmanualshaderbaker.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzmorphloaderpro.dll
dzobjexporter.dll
dzoptitexclothbasic.dll
dzpolygongroupeditortool.dll
dzprimitives.dll
dzpropertyeditor.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzrslshadercompiler.dll
dzsavefilters.dll
dzscriptedrenderer.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dzshadermixerbase.dll
dzshadermixergui.dll
dzsmartcontentpane.dll
dzspotrendertool.dll
dztextureatlas.dll
dztransferutility.dll
dzu3dexporter.dll
dzweightmapbrush.dll
dzwinvideo.dll
sdk_sceneinfopane.dll
dzmimicbasic.dll
dzpowerpose.dll
WARNING: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
Total class factories: 1191
WARNING: 3DConnexion Plug-in Error: Could not create Device, CoCreateInstance failed
3D mouse support library could not be loaded.
Creating interface
Successfully created OpenGL viewport for Viewport1.
Successfully created OpenGL viewport for Viewport2.
Successfully created OpenGL viewport for Viewport3.
Successfully created OpenGL viewport for Viewport4.
Executing startup script...
Started in: C:/Program Files (x86)/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 2048 Height: 2048
Compiling OpenGL Shader...
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Fragment info
0(29) : warning C7050: "rgb" might be used before being initialized
Shader Program successfully linked.
Loading Startup Scene : C:/Users/Link/Documents/DAZ 3D/Studio/My Library/People/Genesis/Genesis.duf
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4EyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking XBulgePosLeft & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking XBulgePosRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking XBulgeNegRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking YBulgePosLeft & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking YBulgePosRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking YBulgeNegLeft & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking YBulgeNegRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking ZBulgePosLeft & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking ZBulgePosRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking ZBulgeNegLeft & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking ZBulgeNegRight & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4EyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/MCMV4HdEyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FHMVictoria4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Victoria 4/FBMVictoria4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/MCMS4HdEyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/MCMS4HdEyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/MCMS4EyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/MCMS4EyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FHMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Stephanie 4/FBMStephanie4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedR.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/MCMM4HdEyesClosedL.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FHMMichael4.dsf.
WARNING: fileinput\dzassetdaz.cpp(5040): Duplicate formula found linking Value & Value in /data/DAZ 3D/Genesis/Base/Morphs/DAZ 3D/Michael 4/FBMMichael4.dsf.
File loaded in 0 min 14.9 sec.
Loaded file: Genesis.duf
Platform bits: 32
Qt Version: 4.8.1
Stepping ID = 2
Model = 1
Family = 15
Extended family = 6
APIC Physical ID = 1
MONITOR/MWAIT
x87 FPU On Chip
Time Stamp Counter
APIC On Chip
PTE Global Bit
Page Size Extension
CFLUSH Extension...
As you can see when i tried to render the program just crashes without registering i even started the render in the log file.I just tried to render the default scene(only blank genesis) Which is why after loading genesis.duf or whatever it says starting daz again.
Looks like the problem is an update gone awry...basically, you have mismatching content versions.
You've got the Gen4 Shapes? That needs to be uninstalled and the latest version installed (reset your download for it..)
k sorry i haven't been back in awhile but i have fixed the duplicate file issue.Daz still crashes upon beginning a render.Here is the log:
Platform bits: 32
Qt Version: 4.8.1
Stepping ID = 2
Model = 1
Family = 15
Extended family = 6
MONITOR/MWAIT
x87 FPU On Chip
Time Stamp Counter
APIC On Chip
PTE Global Bit
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Cache Size = 2048
Available Virtual Memory: 3912 Mb (4103024640)
Current Memory Usage: 17%
Tue Oct 2 23:49:47 2012
Total temp disk size: 764899 Mb, Available: 228906 Mb
Locale: en_US
Creating managers
Reading help index
Using GLEW 1.7.0
GL_ARB_copy_buffer
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_gpu_shader5
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_S3_s3tc
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_Cg_shader
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_gpu_program5
GL_NV_gpu_shader5
GL_NV_point_sprite
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
: NOT INITIALIZED
VBO supported
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzautofit.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzobjexporter.dll
dzprimitives.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzsavefilters.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dztextureatlas.dll
dzu3dexporter.dll
dzwinvideo.dll
dzmimicbasic.dll
dzpowerpose.dll
Creating interface
DAZ Studio Started
Fragment Shader:
Linking Shader:
Fragment info
File loaded in 0 min 4.5 sec.
The specs you posted earlier show 8 GB and 64 bit Win 7...
The log shows 1 GB and Win XP...
Something isn't right here...and I'm suspecting an OS problem...probably UAE/account restrictions/firewall or something similar forcing DS to be installed in 'compatibility' mode.
If either program only has 1 GB available, then yes, it will crash...with all but the smallest scenes. DS4, on my system uses a couple hundred MB just sitting there. Add in one Genesis and it climbs to around 400 MB.
fixed the compatibility issue here is my new log.Daz still crashes while rendering.Bryce doesn't crash while rendering just creates extremely pixelated renders.
Platform bits: 32
Qt Version: 4.8.1
Running on Windows 7, Build 7600, No Service Pack Installed
Stepping ID = 2
Model = 1
Family = 15
Extended family = 6
MONITOR/MWAIT
x87 FPU On Chip
Time Stamp Counter
APIC On Chip
PTE Global Bit
Page Size Extension
CFLUSH Extension
MMX Technology
FXSAVE/FXRSTOR
SSE Extensions
SSE2 Extensions
Cache Size = 2048
Total Physical Memory: 4095 Mb (4294967295)
Available Physical Memory: 4095 Mb (4294967295)
Available Virtual Memory: 3919 Mb (4110282752)
Current Memory Usage: 22%
Wed Oct 3 14:28:26 2012
Total temp disk size: 764899 Mb, Available: 211183 Mb
Locale: en_US
Creating managers
Reading help index
Using GLEW 1.7.0
GL_ARB_copy_buffer
GL_ARB_depth_clamp
GL_ARB_draw_buffers
GL_ARB_gpu_shader5
GL_ARB_imaging
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_point_sprite
GL_ARB_robustness
GL_ARB_shadow
GL_ARB_sync
GL_ARB_texture_rg
GL_ARB_timer_query
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_S3_s3tc
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_minmax
GL_EXT_Cg_shader
GL_EXT_fog_coord
GL_EXT_gpu_shader4
GL_EXT_packed_float
GL_EXT_shadow_funcs
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_sRGB
GL_EXT_timer_query
GL_EXT_vertex_array
GL_NV_blend_square
GL_NV_copy_image
GL_NV_depth_clamp
GL_NV_fence
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_gpu_program4
GL_NV_gpu_program5
GL_NV_gpu_shader5
GL_NV_point_sprite
GL_SGIS_texture_lod
GL_SGIX_shadow
GL_SUN_slice_accum
GL_WIN_swap_hint
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_NVX_DX_interop
WGL_NV_DX_interop
WGL_NV_DX_interop2
WGL_NV_float_buffer
: NOT INITIALIZED
VBO supported
Loading plug-ins:
aniMate2.dll
dazscriptide.dll
dz3dconnexion.dll
dz3dmouse.dll
dzalignace.dll
dzautofit.dll
dzbrycebridge.dll
dzbvh.dll
dzcolladax.dll
dzcomponents.dll
dzcr2exporter.dll
dzcustomizedlg.dll
dzdformeditor.dll
dzeasyloader.dll
dzexpexporter.dll
dzfbxexporter.dll
dzfbximporter.dll
dzfiguresetup.dll
dzhexagonbridge.dll
dzimageio.dll
dzjointeditor.dll
dzlayerededitor.dll
dzlayerfilter.dll
dzmaptransfer.dll
dzmorphfollower.dll
dzmorphloader.dll
dzobjexporter.dll
dzprimitives.dll
dzpuppeteer.dll
dzpz3importer.dll
dzrenderedit.dll
dzrenderlibrary.dll
dzsavefilters.dll
dzscriptedsteps.dll
dzshaderbaker.dll
dzshaderbuilder.dll
dzshadereditor.dll
dztextureatlas.dll
dzu3dexporter.dll
dzwinvideo.dll
dzmimicbasic.dll
dzpowerpose.dll
Creating interface
DAZ Studio Started
Fragment Shader:
Linking Shader:
Fragment info
File loaded in 0 min 2.0 sec.
Please note that it still only reads half of my physical memory
Bryce will always use no more than 4 GB (or even see any more...it's a 32 bit program and that's a hard limit)
Is DS 32 or 64 bit?
