dmc file extension?
digitell
I just ordered something and a file with a .dmc extension was available for download..does anyone know what this is?
digitell
yup, its a file that Mimic uses to configure lip syncing
Hi thanks for replying..I tried to run it but windows was asking me what to use to run it..Windows did not recognize it..what should I do with it if anything?
if you don't have the Mimic program its useless and you don't need it, if you have Mimic then its kool and good to have
Hi and thanks for your help..yep I got the Mimic but have not used it..I will try to figure out how to use it and will save it to my puter.
Thanks again! :)
Mimic is fun and pretty easy to learn, you load a sound file, load a model, load the dmc for the model you want to use and it does most of the hard work for you, just minor tweaking is left to do
what figure did you get with a dmc?
I havnt used the Mimic for over a year but I have a filed saved for when I was playing with it.
I just now bought : Eggbert the toon Duckling
http://www.daz3d.com/shop/eggbert-the-toon-duckling
I need to break out Mimic again and play with it some more. :)
kool, looking forward to seeing what you come up with
I don't have eggbert, might need to add him to my wishlist
Hey thanks! I will look you up when I creates somethin!
Cheers!
