OT: Explorer crashes all the time now
2»
  • RAMWolffRAMWolff Posts: 10,374
    Thanks for the link LG.  The scan I was doing froze up.  Not the computer but the scan using that ESET scanner.  So I just aborted.  I'll go there then and get a fresh copy of MBytes and see if that works..
  • LeatherGryphonLeatherGryphon Posts: 12,314
    You're welcome.  Just be sure to go to ".org" NOT ".com"  !!!!!!!!!!!
    Run the freshly downloaded copy while still in "Safe Mode with Networking".  I've had a couple instances where running MalwareBytes in full running mode will find the problem and say it's been fixed but shortly afterwards will reappear.  But after running while down in a "Safe Mode" seems to clobber a few more hidden seeds of infection.
  • nonesuch00nonesuch00 Posts: 18,863
    edited March 2016
    It's been a long while since I have had a Explorer crash but the crash dumps when it happen will be here:
    <System Drive>\Users\<USER>\AppData\Local\CrashDumps
    Post edited by nonesuch00 on
  • almahiedraalmahiedra Posts: 1,372
    mjc1016 said:
    Hard drive crashes...it's not a matter of 'if', but rather 'when'. (And the 'when' is usually when you can least afford it...time/money/work).
    Two in few months on me. Secondary disk D die in June, principal disk C is in comma since November. They both began with Explorer freezing, these had bad sectors. Currently I have my SO in a 200 Gb partition of a WD My passport external disk. The first thing that had die in all computers I had had was the HDD.
