OT: Help GIMP is makeing my head want to exlode!!!
carrie58carrie58 Posts: 4,108
Okay so I haven't been using GIMP much the last couple of months but with deviney's brushes in fast grab I admit I did a BIG fastgrab,well I put them in the brush folder of GIMP same as I've always done with feebie brushes,andopened GIMP,or I tried to open GIMP, it runs for about 15 minutes then throws up a fatal error window ........WTF!!ok so I go and download the latest stable version of GIMP ,urk!! same deal only it throughs up other error files from my freebie brushes I've been using with no problem for a couple of years .......ok unistall ,reinstall ,same issue .......So is there a limit to how many brushes GIMP can deal with ,if so is there a work around??
 I want to play I want to create ,I don't want this headache ..........so i saved screen grabs  of the warnings and such ,I'm using Windows Vista (yes I like it ,it's all I know)12GB ,can anybody help or at least give me a shoulder to cry on in frustration ,and talk me out of beating the ever loving poop out of the computer!!
    I remember older versions choking when too many brushes were trying to load at startup. It's been a while since I've used it- does gimp have a method on the brush panel to load brushes manually? IIRC it should be in that little triangle on the right side of the panel. If so, move the brushes to a folder gimp can't read, and just load brushes as you need them.
  • LinwellyLinwelly Posts: 6,063
    see as well this discussion, there are some hints as to what you can do http://www.daz3d.com/forums/discussion/74199/fast-grab-rons-brushes/p1
  • carrie58carrie58 Posts: 4,108
    Thank you for the responses Vaskania,and Linwelly
