How do I move the sunlight on the whole scene in Bryce
tdrdtdrd Posts: 0
edited December 1969 in Bryce Discussion
I am finding my whole scene is a bit dull and needs more sunlight.
I cannot see where you can reposition the sun on the whole scene....
I HAVE looked but it's not coming to me...
    Click the tab at the top that says 'Sky & Fog'
    Then you will see a large ball to the right... on that ball is a representation of the sun's position.
    Click on the ball and drag to move the sun.
    Also if you go into the sky lab (double click on that ball) and choose the Sun tab, you have control over the sun's position size and brightness.
  • HoroHoro Posts: 11,631
    Click on Sky & Fog on the shelf as TheSavage64 said. Then click on the small cloud with the rainbow. This opens the Sky Lab which gives you control over the sky and you can set the sun's position numerically, if you prefer.
    671 x 138 - 27K
  • David BrinnenDavid Brinnen Posts: 3,136
    1 - click on the rainbow behind the cloud.
    2 - top arrow, global shadow intensity - how much light goes through solid objects - set at 100 I recommend.
    and "lower arrows" diffuse and specular settings - let you adjust the suns light output.
    695 x 560 - 179K
    274 x 188 - 26K
