Checkerboard
I am looking for a checkerboard, checkers game in progress, to be placed on a small table. I can find chess boards and other board games, but no checkers. Any suggestions?
Would a chess board with vertically scaled cylinder primitives work? In 3delight you could add a Shader Mixer shader using the Wave pattern to get the lathed look of real draughts pieces, in Iray you'd need to make a custom map (and would need a fairly high level of sub division if you needed to see it as displacement rather than a normal map).
https://www.renderosity.com/mod/freestuff/checkers-set/19239
This is on sale now, and has a nice board: http://www.daz3d.com/gentlemens-game-room
And there’s a blank board with this $2 set: http://www.daz3d.com/board-games
You could easily find a texture online (or make your own).
And I agree, you could make a cylinder primitive for the pieces. If this is for a close-up render and you need something with more detail, let me know (via PM) and I could whip something up for you tonight.
Mike
I just glanced over at ShareCG, and they have a set for free. Just sent it to you via PM.
An older set available here http://www.sharecg.com/v/71248/browse/11/Poser/Cards-Dice-Backgammon-Chess-Checkers
It's set up for Poser, but could be tweaked.
edited to correct typo, fancy not getting Poser right
