DS G3 hair into Poser to fit V4?
daveso
there are quite a few hair products designed for G2/3 characters. Can these hairs be brought into Poser and used of V4?
or even Pauline
G2 hair might be usable via the DSON importer, using the usual "move/scale/rotate/morph to fit then parent to head" technique for using hair not intended for your target figure.
G3 hair most probably uses dual-quaternion rigging like G3, so it won't work in Poser unles you re-convert it to triax rigging so that it has a chance to work via the DSON importer.
