Genesis JeanZ render problem
Is there a patch for the artifacts that appear in a render of the shorts from Genesis JeanZ ?There seems to be "ghost" pant legs that show up in the render only.Any help getting rid of them will be welcome. Thanks !
In DS? Iray or 3delight render? I suspect you are using Iray, in which the materials would not have been tested, and the transparency map or Cutout Opacity value need tweaking - for which you would have to seelct the affected surfaces and apply the Iray Uber Shader base manually, otherwise DS will apply it with default conversion settings.
OK, it isn't using maps at all. Select the JeanZ, then in the Surfaces pane Editor tab (or using the Surface Selection tool in the viewport) select the Pants and the Capris surfaces (ctrl(Win)/cmd(Mac)-click to select the second). In the Presets tab of Surfaces go to Shaders>Iray and apply the Iray Uber Base. Go back to the Editor tab, find Cutout Oapcity and set its value to 0. That should then work (assuming that you are using Iray in DS to render).
Thanks ! I'll try that tonight.
