Payload Error
When i try to install the manager, it displays an "unknown" size during the download, then once finished, when i launch it, it Says:
Installer payload initialization failed. This is likely due to an incomplete or corrupt downloaded file.
http://prntscr.com/bl9ba2
Any Help Please?
  • Richard HaseltineRichard Haseltine Posts: 112,232
    Have you tried using a different browser?
  • marsbondmarsbond Posts: 22
    edited June 2016
    Yes, it either stops downloading that i'd have to download it again, or displays the same error message.
    Post edited by marsbond on
    If you can try downloading over a diffrent connection (library/coffee shop, or at a friend's house). I haven't seen a lot of complainbts about speeds or reliabiality so, on current evidence, I don't think there's a general issue. If you can't try a different connection I would suggest, if you will, waiting to try again tomorrow (or late today) and if it still fails open a support ticket.
    I tried with 3G Key this time, and it' s still the same thing.
  • SixDsSixDs Posts: 2,384
    Does your device (computer or whatever it is that you are using) have an ethernet port? (Thats a cable connection - RJ45). If so, you could try using an ethernet cable to connect directly to your router/modem, rather than using WiFi, which should give you a more reliable connection.
    I tried that, didn't work.
