Missing studio folder
I was getting a suport folder not found erro when trying to load v4/m4 figures and after I tought I solved the issue I ended up with a new problem. the studio folder is no longer showing up in my daz studio formats tab. any idea of  what I screwed up?
1280 x 1024 - 217K
  • Richard HaseltineRichard Haseltine Posts: 112,232
    The Support Folder not found is probably because you installed the figures to the Program Files folder, which you should not do in Windows Vista or later - it's looking for the \Runtime\Libraries\!DAZ\FigureName folder inside the Poser format content directory but having the content in the application folder is likely to lead to that being in the VirtualStore folder. As for the new issue, which folder is it that you are missing?
  • FabeFabe Posts: 232
    Well in the DAZ studio formats in addtion to "My libary" ansd "My DAZ 3D mibary" there was a folder called "studio" after messing around with stuff I don't really understand its no longer there
    If you can find which "Studio" folder it was you could cut its contents (the Data, Runtime etc. folders) and paste them into one of the actual content directories - C:\Users\Fabe\Documents\DAZ 3D\Studio\My Library for example - and allowing Windows to merge the folders when prompted.
