Studio 4.9 *without* PostgresqlCMS?
JOdelJOdel Posts: 6,322
Is it possible to run 4.9 without the PostgresqlCMS running in the background? It's messing up my Adobe software, and quite frankly, I use Adobe software more than I use Studio.
I don't use Connect. I don't use DIM. I don't use metadata or smart content. I download and install everything mannually, except for the stuff that comes in the bitrock installers -- and those require installation on my internal hard drive, which isn't where I keep my content libraries.
Will Studio run without this app? What can I expect to not work if I delete it?
Further info: I'm on a 1-year-old iMac running ElCapitan.
Post edited by JOdel on
  • BejaymacBejaymac Posts: 2,018
    Simple answer is Yes, DS has no real need for the CMS or Connect and IMHO runs better without them clogging your hardware.
  • Richard HaseltineRichard Haseltine Posts: 112,232
    Do note that PostgreSQL runs only while DS or Install manager (or Carrara) are running, it isn't an always-on process the way Valentina was. The CMS is used by some other features (AutoFIt, for example) beyond the visible content management aspects.
    No CMS is not needed for Auto-Fit, all it does is automate the Fit-To option for conforming items that don't have that set.  You can still manually Fit-To.
  • JOdelJOdel Posts: 6,322
    Oh good. What currently happens is that every time I boot the computer I get the panel for installing it. And if I authorize it, it waits a few minutes and then I get the installer program, which removes the previous day's copy and reinstalls it. I'll just cancel and if it's already installed, I would imagine that it will be accessible to the program when I launch Studio.
    If it only runs when Studio is running then I don't know what's messed up Photoshop 2015 I was able to run it before I upgraded Studio from 4.8, but not now. And InDesign has some glitches as well. Although it does at least run.
