shaders
Hi,
Exist the shaders that can i use for carrara, daz and unity3d? Or at couple as carrara->unity3d, or daz->unity3d?
  • Richard HaseltineRichard Haseltine Posts: 112,232
    You mean a single shader that will work in all three? Not as far as I am aware. It might be possible to get close using a PBR set-up in Iray and Unity, I'm not sure whether Carrara does PBR or how close it can get if it doesn't, but they would still need to be sahders (or shader settings) for each application.
  • ArisguardArisguard Posts: 122
    ok, so universal shaders(compatible with lot software) don't exist
    Sadly no, though with things like MDL we may be getting closer for some classes of render engine.
    MDL isn't the only 'universal' shader language...3Delight has OSL (OpenShadingLanguage).
