Area Render Question
Ok, this may seem a silly question but I'm still learning,learning and more learning all the ins and outs.  It could be on the tip of my nose and I wouldn't see it. O.o    Anyway is there a way to render just one part of a scene and save it? For example if I rendered a complete scene, saved out the image and then realized a small mistake that I wanted to correct without re-rendering the whole image again, could I do like a spot render of that area and be able to save it?  I tried using the spot render, but it wouldn't let me save it.  I know when I use to use Poser I could do this and then composite the correction in photoshop.
Any useful help is always greatly appreciated. :)
Mel
  • SzarkSzark Posts: 10,634
    Spot render Tool > Tool Settings Pane and choose "New Window" that will allow you to save the area at full size with the rest being transparent if you save as PNG etc.
  • Richard HaseltineRichard Haseltine Posts: 112,232
    Use the Spot Render tool (from the Tools menu if it isn't on a toolbar) and from the Tool Settings pane set it to render to a new window.
  • Thank you Szark & Richard!  Really appreciate that. :)
