zBrush texture issue.
Angel_2232633Angel_2232633 Posts: 1,204
Hi. I'm trying to make a texture map for G3F that I was going to converet into an Alpha. In zbrush when I go to Texture Map and hit "New from Masking, this happens... It's a total mess... This is the torso UV
I have the sub level at 4 as well with the texture map set at 4096
It was supposed to be an Alpha for Tan Lines
551 x 551 - 10K
1600 x 900 - 362K
Post edited by Angel_2232633 on
  • Cris PalominoCris Palomino Posts: 13,082
    Are you using separating out the polygroups that are on the torso map, so only they are visible, when you use New from Masking in the texture panel?
  • Angel_2232633Angel_2232633 Posts: 1,204
    Am I supposed to do that?
    If you are using the New from Mask button in the Masking panel, you are working with a figure with various maps.  You need to tell ZB which map by hiding all but the parts for, in your case, the torso map.
    Ah thanks I'll try that.
