Lighting Question
I am putting multiple linear point lights in a scene and would like to be able to "link" them so I can turn them all up and down (Intensity, Falloff, etc) at once instead of changing them each manually. Does anyone know if this is possible / if there might be a tutorial on the subject? Thanks.
  • PetercatPetercat Posts: 2,322
    I believe that if you go to the scene tab and select the ones that you want to adjust together, then the parameters tab and do the same, any adjustment will affect all. I don't know how to permanently link them, though. Maybe you could parent them all to one, then "select children"?
  • mark128mark128 Posts: 1,033
    If you select them all, you can change all the prameters at the same time in the parameters tab.  If you put them in a group, it would make it easier to find them all in the scene tab and select them all.  Also, if you wanted to move all the lights around, you could move the group.
  • CostelloCostello Posts: 97
    Thanks, guys.
