Object Texturing UVs
Hello all,
Is there a way to assign separate shaders/textures to an obj that don't have any? just one color no maps just the UV.  The object i want to modify are the Hitman sunglasses by Daz Sarsa Bobbie25. I want to put a shader on the lenses. thanks
  • Richard HaseltineRichard Haseltine Posts: 111,939
    Any model from Daz shoudl be UV mapped, whether it has a textuer applied or not. If you want to apply a particular material to part of an object that doesn't currently have a named surface distinct from the rest of the mdoel, but which is made up of whole polygons, you can select the polygons with the Geometry Editor tool then right-click, Geometry Assignment>Create Surface from Selected...
  • j_stnkj_stnk Posts: 205
    Thank you Richard!
