the freak
hello!!!   I try to use the freak character... I have buyed it, with the morph injections, but it stays unemployed since today...  I have installed everything, but the morphs, after the morph injections, doesn't work... For example, to get an ogre belly, I have some polygons growing disorderly, and that's all...   as The Freak is a classic character, what happens, and how to get the differents morphs working correctly?? thank you for your comments!!!
  • bighbigh Posts: 8,147
    he doesn't work right in DS also - so no help
    He doesn't?
  • wsterdanwsterdan Posts: 3,607
    He doesn't?
    If you load the character and apply the large belly morph (as mentioned above), the polyps push forward and look as if they're about to tear off at the bottom. I didn't test any further, but gave it a quick try to see if I could see what they're talking about.
    -- Walt Sterdan
  • DiomedeDiomede Posts: 15,461
    Could you provide some screen captures?
    Which morphs exactly?  I've tried BellyBulge, BellyOut, and Ogre and I'm not seeing a problem in DS4.8 or 4.9
    edited April 2016
    The Freak and its morphs works for me.  Windows machine.  Carrara 8.5 latest release.  Loaded from the "Poser" style content runtime
    1)  I load The Freak from my folder that has "Runtime" in the name and the Figures subfolder  (traditionally Poser style figures - CR2 format)
    2)  I apply inj morphs from Poses subfolder
    3)  I tested 3 separate belly morphs by setting each to 1 and the others to zero.  Each seemed to work fine.
    EDIT: note - my content folder has a custom name (Stuff for Studio Runtime), I believe the default name is My Daz3D Library Runtime, with keyword "Runtime"
    1589 x 1005 - 318K
    1920 x 1035 - 394K
    1691 x 753 - 249K
    Post edited by Diomede on
    got Freak to work
    load Freak
    goto
    morphs and maps
    click all Freak body (+) - works for me now
