Bug when selecting keyframes
I tried to report this through the bug tracker, but it would not allow me in.
After sometime, trying to select several key-frames by dragging the Pick tool across, will no longer work.
Only after exiting Carrara and running it again you can temporarily fix the issue.
Selecting kef-frames one by one with the shift key always works, but its tedious when you have many to select.
The bug tracker requires you to set up a name and password separate from your DAZ login for the forums.
