What I'm doing wrong?
I can't select the arm properly with the field in the image two. It appear to be selecting the hand but actually is nothing where is the field. What I'm doing wrong?
Hope you could understand my enlglish is sh*t
Thanks!
1366 x 728 - 198K
1366 x 728 - 193K
  • Try using the crossed arrows in the upper right corner of the viewport window to move the figure down and to the left; that should enable you to select the arm.
    D-Formers can behave weirdly when the mesh is moved or morphed away from its default position (the T-shape). Does the arm have to be up like that? You might be able to apply the D-Form with the arm down, then spawn a morph from the D-Form, then raise the arm back up.
  • I can't. The figure moves with the dform sad
  • Richard HaseltineRichard Haseltine Posts: 112,268
    Which bit are you moving? Moving the base affects only the centre point for rotations or scaling, moving the field affects what is modified by the DForm, moving the DForm itself modifies the targeted mesh.
    No, don't move the D-Form towards the arm, move the arm back down to its default T-pose position.
    Looking at your screenshots, it's hard to see one important thing; which part of the figure are your D-Forms parented to? We don't need to see your Smart Content, but the Scene tab would be useful. Could you move your Scene tab over to the left-side tab group and take another screenshot, showing the Scene tab on the left and Parameters tab on the right?
