Background map!
edited December 1969 in Hexagon Discussion
I got a nagging issue in HEX! I have a background set up. NOT IN or on the BACKGROUND Proper but on object so I can model my f-4 corectly! The OBJECT started out as one big object that I assigned the BLUEPRINTS to then CHOPPED it up and use it like seen here. AND it work great.
But everytime I reopen it I have to FLIP the image to set it back right! SEE IMAGE!
Whats up with that! I set the original correctly
800 x 444 - 214K
  • edited December 1969
    Known bug.
    DAZ might not think it's a bug, but IT'S A BUG!!! :-)
    The only workaround I found was obvious but irritating: Flip your texture files in an image editor so that they're upside down - then hex will flip them rightside up when it loads them.
  • XyetztXyetzt Posts: 27,602
    Known bug.
    Sounds very irritating.
  • hiker_1hiker_1 Posts: 0
    off-topic, b ut where did you get the nice 3-view of the double ugly?
    also, just a hint, you may want to try out the gordon surface tool - it greatly simplifies the shape of the fuselage and even the wings....
  • RJ StubbsRJ Stubbs Posts: 0
    You can find some really cool blue prints and vectors here:
    http://www.the-blueprints.com/
    HUM I will give that a try! I have just always gone basically poly by poly. I may restart and try that the more I think of it. AS far as the Blueprints I found the best resource I have found even better than that BLUE-PRINT site and its free! OF course its form RUSSIA! Go figure its
    http://www.airwar.ru/
    Its all in russian and you have to guess at what your aircraft is but its the best site i have found yet! The only issue I have is that at least with the one o used here for the UGKY f-4 is that the CROSS SECTIONS didn't quite match up to the side, top, and front views. But they were a great guids
    ALso a hard issue to consider while thinking of how to set the F4 up is the Air intakes! sort of in the middle its attached to the main body but then separates
  • ausairausair Posts: 0
    When you uvmap the plane that the image is to be placed onto there is a option to swap uv's there which will get your texture the right way up and it will stay that way.
    The option to flip texture horizontally or vertically in the material settings is bugged.
    Hey I am aware of the bugs but I still think for the money Hexagon In my opinion is a first class modeler! I will never use but of a fraction of what it is capable of! I have had Lightwave 8 for 5 years now and never even open it any longer! I did some simple Modeling work in it and it felt like I was signing a check with my wrong hand.
    Also any TUTORIAL your gunna a see like on youtube in any modeler such as MAYA translates over into Hex very easily!
