plugins starting with dsp_ ?
When I look at installed plugims for Daz Studio 6 there are 11 with names starting dsp_ which all have red plug icons and say they failed to load. Some say they are for an unsupported version of Daz Studio and some saiy they are not valid plugins or are for a different version of Studio. To add the the confusion when I just started Studio, Winbdows flashed up a series of boxes saying it was blocking some part of the application and it mentioned these plugin names saying it could not verify who published them.
Does anyone know what these are?
If you check the other plugins, including the default ones, you'll find that DSP_ on pretty much all of them in DS6.
My best gues, it's just used to differentiate between the older versions and DS6 compatible.
Windows 11's AV does not like anything that isn't digltally signed. You'll either have to change your AV settings, or add exceptions to the av rules to get around it.
Also, there are some reports that the latest DS6 has problems with some plugins and they'll need to be updated to run again.
Be sure to check that any plugins you used in ds4 have been updated to DS6 before trying to use them.
If there are no updated versions, you can figure they haven't been and won't work.
The installed plugins window doesn't show dsp_ in front the plugins that work.. I suppose it only does for these because it can't find the name of the plugin. I use DIM to install plugins and that should tell me if there are any updates available
Ok, we're talking about two different things. sorry about that.
You're talking about the Load/Name in the About Installed Plugins popout, and i'm referring to the actual file names, which are shown in the about/tips section below the list of plugins in the popout.
The reason you're seeing the file name, and not the product name, is because that information is in the file it can't load.
DIM can sometimes be a bit hit or miss on reporting updates for products.
I'd check the readme section of the wiki, here, just to make sure if there's a reported update or not.
If it's been updated, but dim isn't showing, you'll need to delete the previously downloaded file to trigger DIM to allow a new download.
The issue only happens to DS 6.26 and it comes from the new plugin version checking mechanism adopted by DS 6.26 (devlopment SDK has been updated as well...). All the plugins built with DS 6.25 SDK fail to pass the version checking in DS 6.26, so they're shown as "dsp_xxxx" in the dialogue of About Installed Plugins....
We need to fill the tickets, as well as notify the developers of the plugins from the 3rd-parties sites, and wait for the plugin updates ~~
Or, if you have older DS 6.25 installation packages, roll them back...
I worked out what most of them are from the file names and none of them say they have an update for thiis issue, although I often find that DIM installs updates for things that don't have any updates shown in the readme file. The ony one I couldn't guess the name of was dsp_hm_engine but that sounds like it could be a support .dll for something else.
dsp_hm_engine is the HedgeMaker 1 engine for Studio 6, currently built for DS 6.25, and the DS 6.26 update was submitted the day after we learned about the SDK updates, so almost a month ago now.
