Resource Error
Superpers16Superpers16 Posts: 2
edited April 2016 in Daz Studio Discussion
When I open the DAZ Studio, an error occurs "Resource Error"
How to solve the problem?
Post edited by Superpers16 on
  • Superpers16Superpers16 Posts: 2
    edited April 2016
    Когда я открываю DAZ Studio, возникает ошибка "Ошибка ресурса"
    Как решить проблему?
  • Richard HaseltineRichard Haseltine Posts: 112,229
    Did you install the PostgreSQL? What operating system and security software are you using?
  • I get this error messages sometimes too, and Daz won't load up anything. Today, however, it's working fine.
  • frank0314frank0314 Posts: 15,120
    You need to check if Postgre SQL is on. Check in Task Manager under Processes
  • Did you install the PostgreSQL? What operating system and security software are you using?
    OS: Windows 7 (x32) Anti-virus: Avast, but I switch off the security, did not help. PostgreSQL is installed.
    OK, if you start Daz Studio and then look in the [processes tab of Task Manager (right-click the Windows Task Bar, Launch Task Manager) do you see several instances of PostgreSQL in the list?
  • OK, if you start Daz Studio and then look in the [processes tab of Task Manager (right-click the Windows Task Bar, Launch Task Manager) do you see several instances of PostgreSQL in the list?
    No, in Task Manager, process "PostgreSQL" is not.
    Please double check that the 32 bit version of PostgreSQL is installed, and not just the Valentina to PostgreSQL conversion tool.
  • Please double check that the 32 bit version of PostgreSQL is installed, and not just the Valentina to PostgreSQL conversion tool.
    "PostgreSQL CMS" and "PostgreSQL From Valentina CMS Conversion" is installed.
