Modify garments
Hi everyone. Does exist some bundle in DAZ or something to stretching or modify garments or fabrics? Thanx
  • felisfelis Posts: 6,656
    Modify garments is a broad term.
    Stretching, like making a shirt longer?
    To my knowledge there are no products that generally can help with that.
    If a product support dForce you can change dForce settings in the clothing, e.g. increasing Contraction/Expansion to 110-120 that will make the clothing larger.
    If you want to remove part of a clothing, you can do it my modifying or make a Cut-out oppacity map that can make part of a clothing invisible.
    Mesh grabber is an option if you will make smaller changes, but I will only recommend it for small changes.
    Normally if you want to modify clothing, you would take it into a modeller and make one or more morphs for that dedicated clothing item.
    Can you come with an example of what you wanted to do?
