Add D-Force modifier
dennisgray41dennisgray41 Posts: 1,016
edited October 2 in The Commons
[Add D-Force modifier] Static force/dynamic force. What are these:?
  • Matt_CastleMatt_Castle Posts: 3,309
    Static is for when you don't want the object itself to simulate, but you need to adjust things like its friction and collision offset to adjust how it affects other things that are simulating.
    Dynamic is the "standard" dForce modifier, and what you want to use in most cases.
    Dynamic Add-ons are a special case used to connect another mesh to a primary object. This might be done for example if the simulated item has grafted parts, or to add a framework mesh that ties parts together (such as buttons that are supposed to be done up) or to provide more structure to the object (such as if a skirt is supposed to have some kind of supporting hoop structure).
  • dennisgray41dennisgray41 Posts: 1,016
    Thanks
