Daz Temp directory
Is there any way for an external program to find the daz tmp directory setting? It is set in the F2 preferences screen. And a script can find it with App.getTempPath(). But I'm running outside of Daz Studio. I'm guessing it's compressed inside some file in the appdata directory.
  • Depends on the program, but because this is a "hidden" folder, it's often ignored by most programs.
    If you change the "File explorer options" to enable "Show hidden files, folders and drives", the program may be able to find it
    Note: this can be "risky" exposing these items, proceed at your own risk.
    What exactly are you trying to do?
  • I assume the aim is to have an app/script get the location of the temp folder so that something can be done with it by the app/script. I think it may be a registry key, but I am not certain.
  • jmucchiellojmucchiello Posts: 2,809
    I didn't think Daz used the registry for some reason. I just assumed there was some platform independent system for saving all this data.
    There's a ton of sub folders/keys... Most of it is dialog defaults, including plugin and script defaults.
    And it is here: \\\Computer\HKEY_CURRENT_USER\Software\DAZ\Studio6\TempFilesDir
    Thanks.
