• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Diffeomorphic UDIM Artefact
mark212160mark212160 Posts: 28
September 1 in Blender Discussion
Blender 5.2.0
Diffeomorphic 5.2.0.3018
G8F material: FW Rebekah HD for Victoria 8
Steps:
- Import a G8F via Diffeomorphic's manual import
- Merge Rigs
- Import standard morphs, including Head, Expression, FACS, Body, JCMs, Flexions
- Import Daz Favorites, including Zev's Breast Control, Bend Control, Tongue Control, Expression Smoother
- Save Local Textures with All Mesh checked
- Merge Materials with every setting unchecked, including Ignore Bump Strength
- Switch to Edit Material tab, set Face as Active Material, press Make UDIM Textures, change Image Size to 4096, check Combine Texture Types and all material zones, and press OK
- Set Face as Active Material, press Overwrite Materials, check only Torso, Lips, Legs, Fingernails, Toenails, Face, EyeSocket, Arms, and press OK
- Switch to Cycles GPU, and the following artefact occurs on the whole G8F mesh.
1669 x 1545 - 4M
  • PadonePadone Posts: 4,371
    September 1 edited September 1
    Support for "all material zones" is experimental and may need to fix some udims by hand. Try step 7 selecting only the materials you need for the skin. Also, if the figure uses LIEs it is always required to bake LIEs first. Your first steps are unneccessary to reproduce the issue as udim doesn't depend on morphs.
    https://diffeomorphic.blogspot.com/2026/08/how-to-make-udim-aka-fix-iray-skin.html
    p.s. In any case to report bugs it is always required to update to the current dev version first, as stables don't get fixed once released. It's currently 5.2.0.3032.
    https://github.com/Diffeomorphic/import_daz/issues/2
    https://github.com/Diffeomorphic/import_daz/archive/refs/heads/master.zip
    Post edited by Padone on September 1
  • mark212160mark212160 Posts: 28
    September 1
    I updated to 5.2.0.3032, followed the same steps as described above, except that I unchecked Combine Texture Types, Pupils, Irises, EyeMoisture, Cornea, and Sclera in the Make UDIM Textures step, and the same artefact is still present.
    Could you explain how to "fix some UDIMs by hand"?
    September 1
    It is explained in the link I posted above. Essentially you check the udim and see if everything is in place. Of course in blender you can sort or move them as you wish, or add fillers, by hand. I will look at your specific case and let you know what I find.
    September 1
    Yes, there's something in the Rebekah textures which makes UDIM fail. Note that G8F or Victoria 8 work fine so this is limited to Rebekah. Now reported to Thomas.
    https://github.com/Diffeomorphic/import_daz/issues/91
    September 1
    Thank you for the confirmation and report!
    September 3 edited September 3
    Ok, I believe I got what it is. It's not a bug in the addon I can't reproduce it on my side, the missing diffuse I reported to Thomas is correct as the translucency for Rebekah is 1.0 so diffuse is zero. It is my fault I didn't notice this before. The issue you get is due to a blender bug, also reported at github, as blender 5.2.0 has issues with 50xx cards, that I guess you have.
    https://github.com/Diffeomorphic/import_daz/issues/58
    To resolve the issue please update to blender 5.2.1, which works fine with 50xx cards.
    Post edited by Padone on September 3
    September 3
    Yes! After updating to 5.2.1, the issue went away! Thank you!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
